oil cooler question
Old Oct 21, 2005 | 08:08 AM
THEROPE's Avatar
Default oil cooler question
on the auto rad's there is a trans cooler but since i have a 5spd i pluged the lines.
well i want to use the trans cooler in the rad as the oil cooler for the block.
my question is where do i run the lines? where on the block is a good spot?
oh and i have a 95 accord ex coupe
Old Oct 21, 2005 | 03:23 PM
P_Adams's Avatar
Default Re: oil cooler question (THEROPE)
Look up a company like TransCool, or do a "GOOGLE!!" search under auto oil cooler and scare up about a ga'zillion hits.
Traditionally some made an adapter which sandwiched between the block and the Oil Filter, allowing both an output and a return hose to be connected.
A remote Oil filter kit would be the same thing.
P
ps: I'd take a moment and ask around about PSI operating pressures for both the Tranmission and the Engine (between 50 & 65 psi). The Trans cooler may not be rated for the Engines psi.
Old Oct 21, 2005 | 05:04 PM
hondadude's Avatar
Default Re: oil cooler question (P_Adams)
I saw a really 'Cool' set up... a remote filter that had the lines routed thru the radiator trans cooler. Super 'Cool'....Totally 'Cool'
Old Oct 21, 2005 | 05:10 PM
iam7head's Avatar
Default Re: oil cooler question (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">I saw a really 'Cool' set up... a remote filter that had the lines routed thru the radiator trans cooler. Super 'Cool'....Totally 'Cool'</TD></TR></TABLE>
it's too cool huh? too bad they didnt mention it will drop the pressure by placing a filter there, do you think it will affect your tranny? cool huh?
and to answer the guy's question , DONT use the cooler you have, if you really want a oil cooler get one instead, the atf cooler are built to withstand the oil pressure of the auto tranny, not the block.
there's tons of oil cooler out there, big one, small one, fat one and thin one with a puller fan on. they runs about 100dollar and they are built for the engine's oil pressure.
Old Oct 21, 2005 | 08:01 PM
db8xc1x39
Guest
Posts: n/a
Default Re: oil cooler question (iam7head)
Old Oct 24, 2005 | 04:27 AM
THEROPE's Avatar
thanks
RRRex
Sep 30, 2003 10:59 AM
Screamer
Mar 26, 2003 07:51 AM
HybriDNA
Dec 27, 2002 07:12 PM
Canuk_SiR
Jul 13, 2002 10:01 AM
xci_ed6
Jun 13, 2002 09:55 AM
