O2 sensor
Old Apr 18, 2014 | 09:21 AM
Miggi_Jiggi's Avatar
Default O2 sensor
Can someone please tell me if this is a normal reading or do I have to take action?
ECL P0420, I cleared it the took a voltage reading
I have attached a screen shot for your veiwing. Thank you in advanced
2k accord V6 3.0L
ok so I dont know how to upload the jpeg here are the numbers
o2 1x2 voltage reading is .5 to .8 when accelerating
o2 2x2 voltage reading has no data <<< im questioning this one
Old Apr 18, 2014 | 11:24 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: O2 sensor
Secondary O2 sensor should either hold a steady low voltage reading, or if the secondary combustion is not fully happening in the catalyst, the secondary O2 will follow the primary O2s voltage output.
Old Apr 18, 2014 | 12:46 PM
Thank you, that kind of made sense to me. I will monitor the numbers while in cruising speed. So far so good, looks like it might have been a false/positive in the ECU
Old Apr 18, 2014 | 04:35 PM
MAD_MIKE's Avatar
MM Gruppe B
P0420 is a code that takes a bit to set if the catalyst or secondary O2 are failing. If the catalyst is outright dead the code will come back fairly quickly.
Chee_dog
Jul 20, 2007 08:21 PM
jxkim89
Dec 30, 2006 02:55 PM
boost fed ls
Aug 31, 2004 07:45 PM
Shakes
Apr 28, 2004 08:45 PM
00SIBOOST
Feb 24, 2003 07:36 AM
