No Start 96 Accord
Old 01-05-2012, 05:18 PM
elnoyl's Avatar
Default No Start 96 Accord
The car sounds like it's firing but won't start. I checked for fuel and spark and it has both. The spark does seem weak because it is more of an orange. It's a 96 accord with a 2.2 non vtec motor. What do i check next? Thanks in advance.
Old 01-06-2012, 09:16 AM
Roader's Avatar
Default Re: No Start 96 Accord
Take the tube off of the throttle body and have someone crank the car while you spray a bit of starting fluid in the throttle body.
Old 01-06-2012, 12:01 PM
elnoyl's Avatar
any ideas?
Old 01-07-2012, 02:39 AM
phootbag's Avatar
It's rude to ignore someones suggestion like you did. If you don't want to try spraying some starting fluid into the intake, fine. You should at least say something like, "Thanks, but I'm going to pass on that", and not just ignore it, post "any ideas?" and pretend like nobody tried to help.
Old 01-08-2012, 08:14 AM
elnoyl's Avatar
if your not going to add anything to a thread stay out of it. If you think starting fluid is technical you don't belong in this forum. Starting fluid isn't a reason for a car not starting and doesn't solve anything.
Old 01-08-2012, 09:07 AM
Roader's Avatar
Technically:
  1. compressed air
  2. gasoline or other flammable vapor
  3. spark
Note that all three have to happen at the correct time.
I suggested a cheap and fast way to check if #2 since you indicated that #3 was present, at least somewhat.
Sorry it didn't work out.
96hondaaccord26
10-07-2014 04:50 AM
Witness7
11-11-2012 11:00 AM
hard_boiled_EG
11-21-2009 07:24 AM
fenton235
08-09-2007 12:57 PM
2muchPSI
12-22-2003 06:58 PM
Quick Reply: No Start 96 Accord
