Needs HELP!
Old Feb 16, 2010 | 07:19 PM
fooboo's Avatar
Default Needs HELP!
I got a Honda 1995 Accord EX auto trans.
I was driving to work and coming back home then
my car was die on the road....i couldn't start the engine....
...but the scenes i was driving...i was driving 45mph on the road...
then the RPM just starting going down....and the brake just LOCK.
I pull over then...couldnt start the engine...
so i was thinking about...probably a Distributor, coil, fuel filter, or something
really gone bad!! or maybe a TIMING belt...i'll have to check it out tomorrow!
sucks...ACCORD has lot of problems...any solution??
VTEC POWER!
Old Feb 16, 2010 | 07:30 PM
busha61067's Avatar
Default Re: Needs HELP!
is the engine turning over?
Old Feb 16, 2010 | 07:43 PM
fooboo's Avatar
i'll have to check it out tomorrow!!
maybe....but theres one reason why the brake lock while
the car is stop??
Old Feb 16, 2010 | 08:05 PM
19Accord97's Avatar
If the belt broke and you tried restarting it....that was an awful choice.
Check the oil level, did you lose your oil and the motor seized up?
Old Feb 18, 2010 | 11:52 AM
fooboo's Avatar
i check my accord this morning...
everything is good and the electrical is kool!
last i find out its a timing belt...it was off...
so i dont know how to install timing belt...
might need a more info...i need a new timing belt!
Old Feb 18, 2010 | 11:59 AM
kadinz's Avatar
GET THE TIMING MARKS, line em up and put the belt on, there should be guides on the web and also the haynes manual thing will help you, also...learn to type in fluent english AT LEAST! sheesh.
Old Feb 18, 2010 | 12:14 PM
fooboo's Avatar
I was reading haynes manual book and it gets me confusing.....
Old Feb 18, 2010 | 11:44 PM
fooboo's Avatar
Default Re: Needs HELP 2!
My Honda accord timing belt went out off the cam gears...
i need a hint for the install and need to know where the line marks
should be at??
Old Feb 19, 2010 | 05:43 AM
GhostAccord's Avatar
Check the Accord FAQs at the top of the forum page. There is a DIY on how to change the timing belt.
https://honda-tech.com/forums/honda-accord-1990-2002-2/1990-2002-accord-faq-1664547/ it's the first link under the heading Engine. You may also want to take a look at the video for the crank pulley tool while your in there.
Good luck
Old Feb 20, 2010 | 01:44 PM
fooboo's Avatar
Thanks a lot...
it help....GOOD INFORMATION!
https://honda-tech.com/forums/showthread.php?t=1664547 it's the first link under the heading Engine. You may also want to take a look at the video for the crank pulley tool while your in there.
Good luck
Jesse13579
Jul 1, 2019 02:58 AM
JoseVillalpan
Engine Management and Tuning
Aug 10, 2017 03:34 PM
Keet_Tha_Sneak
Jan 4, 2014 03:44 PM
Johnoolo
Nov 19, 2012 06:49 AM
dogpile5
Apr 9, 2006 10:25 AM
