need help
Old Jan 27, 2012 | 05:18 PM
AngryFridge's Avatar
Default need help
hi i have a 1997 honda accord lx the past week or so the driver side by the wheel is extremely squeaky when i sit in it squeaks go over a bump squeaks even if im driving and the rodes are a little unbalanced it squeaks i have no clue whats causing it and also when i go through harsh dips in the road it makes a sound i really have no way to describe it.. like a crunch sound? idk
anyways let me now what yall think it is thanks
Old Jan 27, 2012 | 11:56 PM
Pradject217's Avatar
Default Re: need help
Check your shock tower to be sure it tight.
Old Jan 28, 2012 | 08:07 AM
Lost Again's Avatar
There is a long list of other things as well.
Are you doing this or taking it somewhere....and please don't take that the wrong way.
Old Jan 30, 2012 | 10:34 PM
honestly i'll probably end up taking it some where im not the best when it comes with cars was hoping someone on here either had the same expierence or could tell me whats going on haha alllllll i know its just extremely annoying i have to ride around with the stereo on max just so i cant hear it
Old Jan 31, 2012 | 06:45 AM
ricebike's Avatar
start reading the following thread for possibilities of what it can be; it can be anything on the suspension system <shrugs>
https://honda-tech.com/forums/honda-accord-1990-2002-2/annoying-squeaking-noise-suspension-2959180/
in my case, i ended up replacing the upper control arms (the outer ball joints were worn as well) outer tie rods are going now since the boots are torn; his issue on that thread i linked was his lower control arm bushings...
most shops do the inspection for free to see what parts need replacement & take pix of the offending parts + post to verify if they're right or pulling your wallet for some $
Originally Posted by chickinpickle
Sway bar bushings.
Upper control arm bushings.
Lower shock bushings.
Lower control arm bushings.
Upper control arm bushings. (there are two on each side)
Radius rod bushings. (Not likely)
These are all likely suspects. your suspension has a lot of bushings.
poetik02
May 18, 2010 06:15 PM
dthug
Dec 17, 2005 09:17 PM
maivietla
Apr 18, 2005 06:12 AM
Turbo Powa
Jun 29, 2002 10:20 PM
