Need help? With my map sensor
Old Dec 27, 2006 | 07:09 AM
cojak23's Avatar
Default Need help? With my map sensor
Does anyone know how to reinstall a map sensor need help?
Old Jan 3, 2007 | 05:38 AM
Phrost's Avatar
Default Re: Need help? With my map sensor (cojak23)
just use a dremel to cut slots in the rivet heads and then just unscrew them with a flat head (standard screw driver) put new sensor and reuse screws or go to hardware store and match some up..
Old Jan 3, 2007 | 06:42 AM
mmuller's Avatar
Mad Scientist
i dont think i get what your asking.. just feed it vacuum?
Old Jan 3, 2007 | 07:29 AM
95 integra's Avatar
Default Re: Need help? With my map sensor (Phrost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phrost &raquo;</TD></TR><TR><TD CLASS="quote">just use a dremel to cut slots in the rivet heads and then just unscrew them with a flat head (standard screw driver) put new sensor and reuse screws or go to hardware store and match some up.. </TD></TR></TABLE>
Thats great for the TPS, however the MAP just has regular phillips head screws. There is no adjustment, just put it back on (the specific map and car will depend where (90-93 or 94+)).
If its a 3bar then you can just tap the wires and feed it a vacuum line from the intake manifold. If its an OEM replacement then it should be simple enough.
Old Jan 7, 2007 | 04:52 AM
Phrost's Avatar
Default Re: Need help? With my map sensor (95 integra)
my bad i always get those two confused
kpowerdhatch
Oct 20, 2007 02:43 PM
'90crxSI
May 23, 2006 06:53 AM
D_CRX_Si
Mar 15, 2006 12:12 PM
88 rex
Aug 4, 2005 04:58 PM
B18C-RnVA
Aug 19, 2002 03:07 PM
