Lowered
Old Jun 11, 2012 | 07:35 AM
jhof_wagon's Avatar
Default Lowered
Had a good weekend with the wagon.
Fixed the transmission. The solenoid was out. Works like a charm now.
Dropped the front down low. The stock strut was 18" tall, I measured the F&F out to 14 1/2". Was going to do the rears, but the bolts are rusted, any ideals?
I used a ratchet, wrench, heat gun, Dewalt electric impact, and a break bar. Also soaked it in WD-40. No luck.
Old Jun 11, 2012 | 07:38 AM
hondaOchibi7's Avatar
Default Re: Lowered
Type 1s or Type 2s?
Old Jun 11, 2012 | 08:27 AM
djkurious's Avatar
Default Re: Lowered
Breaker bar with 5-foot pipe always has worked for me even when the impact wouldn't.
Old Jun 11, 2012 | 08:30 AM
JuggerNaut-CTR's Avatar
Default Re: Lowered
When I had the same issue trying to remove mine w/ a breaker bar and 4 foot pipe, I ended up getting new bolts and cut the old one off. It took all of 10 sec to cut the bolt than the 15 min I tried different ways to get the rust loose.
Old Jun 11, 2012 | 08:34 AM
1991EX's Avatar
Default Re: Lowered
Try another type of penetrating oil, specifically used for stuck bolts. WD-40 is awesome, but does not have the penetrating abilities of the other specific types. Spray it several times, then use the breaker bar.
This one from autozone is my favorite.
http://www.autozone.com/autozone/acc...er=515413_0_0_
Old Jun 11, 2012 | 09:12 AM
djkurious's Avatar
Default Re: Lowered
If the PB doesn't work with your breaker bar, etc, consider cutting the bolts.
Old Jun 11, 2012 | 10:57 AM
jhof_wagon's Avatar
Default Re: Lowered
Type ones.
If I cut them, would it be ok to go. To the hardware store?
Old Jun 11, 2012 | 12:31 PM
Default Re: Lowered
No, dont cut them then drive to the hardware store. I cut 1, pulled it out, and drove wifes car to the hardware store.
Old Jun 11, 2012 | 12:34 PM
Default Re: Lowered
Good idea to pick up some anti-sieze while at the hardware store so this doesn't happen again if you ever need to pull the struts out later on.
Old Jun 11, 2012 | 01:00 PM
jhof_wagon's Avatar
Default Re: Lowered
lol...
Old Jun 12, 2012 | 07:15 AM
Lil Tones's Avatar
Default Re: Lowered
I used a breaker bar with a 4 foot pipe on mine and snapped the head off the bolt. LOL. Any suggestions?
Old Jun 12, 2012 | 08:22 AM
HonBeer's Avatar
Default Re: Lowered
That looks very gay.
Old Jun 12, 2012 | 10:06 AM
civic98coupe4's Avatar
Default Re: Lowered
I cut mine out, get new bushings too. Should be 15$ a piece then a buck or two for new bolts. It's a pain in the *** for sure.
Old Jun 12, 2012 | 07:40 PM
19Accord97's Avatar
Default Re: Lowered
Talk about a pain in the *** for sure.
We tried a saw all, burning it, breaking it, and everything else. After a couple hours we finally got them out. Luckily I had a rear poly-urethane bushing kit and already had new bolts/nuts from Honda.
Old Jun 13, 2012 | 05:55 AM
jhof_wagon's Avatar
Default Re: Lowered
Im sorry you dont own a wagon.
I think Ill cut it out and order new bolts and bushings. The cars got 205xxx, so time to change **** up. Also got to order new front upper ball joints.
Old Jun 13, 2012 | 10:46 AM
HondaAccord_91's Avatar
Default Re: Lowered
a wagon..... ? why dont you sell it and get a good car?
(no beef)
Old Jun 13, 2012 | 11:02 AM
trashyhatch's Avatar
Default Re: Lowered
(no beef)
please, take the time and enlighten us on what a "good car" is? and what makes his car bad?
PB Blaster, air impact, heat, elbow grease.
Old Jun 13, 2012 | 12:41 PM
jhof_wagon's Avatar
Default Re: Lowered
I want to thank everyone for the advice, the car is hr away at my parents house untill I get my DL back later next month.
I need to replace the front upper ball joints, then she should be ready for the 15x8 +20 185/55/15 rims/tires.
Cant wait to drop the rear.
Old Jun 15, 2012 | 06:44 AM
Default Re: Lowered
(no beef)
Your the typical try and bring someone down cause it makes you feel better about your sorry self aren't cha?
And you think your 91 accord is "good" car. Thats why you have pictures of it up on your profile huh?
Whats wrong w/ a wagon getting a nice wheel and suspension combo to make it look a lil mean?
Old Jun 16, 2012 | 06:40 AM
joshuahettinger's Avatar
Default Re: Lowered
dont cut springs get lowering springs.
Old Jun 16, 2012 | 07:18 AM
jhof_wagon's Avatar
Default Re: Lowered
there not cut :D
my cb7 had progress springs and gr2s
my ce1 has f&f type ones
Old Jun 16, 2012 | 12:50 PM
TheBax's Avatar
Default Re: Lowered
Anyone who hates on a wagon, hasn't seen one done right.
As said above, PB blaster is awesome. I'd recommend picking some up. A little PB, and a breaker bar has done the trick on both of my 6thgens. Except for the damn endlinks for the rear sway bar, but that's another story. haha
Old Jun 16, 2012 | 01:10 PM
djkurious's Avatar
Default Re: Lowered
Those wagons are nice lowered!
Old Jun 17, 2012 | 08:57 AM
jhof_wagon's Avatar
Default Re: Lowered
This is how she sits right now, until I get down there.
Ill try pb blaster, but I do need to replace the bolt, she was getting a little rounded when I was trying everything to break her loose.
btw this how she sat...
Old Jun 17, 2012 | 11:54 PM
Slammed95Cord's Avatar
Default Re: Lowered
i personally love the look of wagons... some wheels and that thing is set!
try PB blaster on the rust... i like how it looks now tho... dumped in the front! great stance
