loud engine?
Old Jun 19, 2004 | 06:27 PM
Acho's Avatar
Default loud engine?
Hey, I purchased my accord used about a month ago as my first car.(Its a 97 4-door, 2.2L I4) Anyway, when I first began to drive it I coudnt help but notice that the engine seemed a bit loud, especially for a family car like an accord. I ignored the problem for about a month, but recently some friends of mine have also noticed the noise, and Ive also began to notice it(and become annoyed by it) more. I think its time to get it fixed, but I have no idea what it could be. Im definetly going to take it to the local honda place, but im just curious as to what could be causing this.
Any ideas?
If it helps, the excess sound is most noticable at 2500-3500 rpm, ESPECIALLY when im trying to accelerate up a hill.
Old Jun 19, 2004 | 06:37 PM
The_Todd's Avatar
Farts in the shower
Default Re: loud engine? (Acho)
It is probably your valves and rockers...typically with hondas the noise is noticeable. Does it make a loud ticking sound?
Old Jun 19, 2004 | 06:44 PM
fw190bvi's Avatar
Default Re: loud engine? (VRDrvr)
you really need to tell us what kinda sound......does it sound like ur mufflers been chopped off?....is it a ticking noise??.......does it sound like a metal rattle??.....does it sound like 2 pieces of metal clicking against each other??......theres about a million defferent sounds......
Old Jun 19, 2004 | 08:26 PM
JDM.Accord's Avatar
Default Re: loud engine? (fw190bvi)
Yeah, cars make a million noises. You're gonna have to be very specific to get any help since its a vague description to begin with.
Old Jun 19, 2004 | 08:43 PM
Acho's Avatar
Default Re: loud engine? (JDMAccord2nr)
There is no clicking or tapping. The engine is simply louder than most equivelent engines. The sound is most similar to the sound of a fart-can equipped car at low rpm.
so basically, while most accords sound like, vrrrrroooom
mine is like VROOOOMMM
Please let me know if you need any more specific details
Old Jun 19, 2004 | 09:00 PM
fw190bvi's Avatar
ok.....so its an exhaust tone????......
either you have a hole somwhere in your exhaust, or somehow, your intake resonator took a dump (dont know how that would work though)
but most likely, your exhaust is bad......stand behind the car, and if its louder, then its def exhaust......
to check for hole location: if exhaust gasses are sputtering out, then its a hole in the piping, or somewhere else up near the front of the car. to check for this, put your hand and inch or two away from the tailpipe. if it makes a puttering (repeating sound like: ...ph..ph..ph..ph..ph) then u have bad piping, otherwise, your muffler has rusted out, and the metal that divides the chambers has been eaten away
Old Jun 22, 2004 | 02:41 AM
secksiman19's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acho &raquo;</TD></TR><TR><TD CLASS="quote">
Please let me know if you need any more specific details</TD></TR></TABLE>
hahahahahahhahaha
whew.....anyway....if it sounds like its equipped with a "fart can" than most likely there is a rusted hole or someone played a mean trick on you!
Old Jun 22, 2004 | 03:57 AM
Al Czervik's Avatar
Default Re: loud engine? (secksiman19)
like f190bvi said:
You probably have a crack or hole somewhere in the exhaust system.
ptmy
Oct 29, 2018 04:21 PM
mfiazzo
Oct 8, 2013 05:13 AM
RAS86
May 28, 2013 07:46 PM
Kongfish
Nov 26, 2012 02:43 PM
