Knock sensor?
Old Sep 2, 2014 | 01:55 AM
Technohedge's Avatar
Default Knock sensor?
Have a h23a that is bogging a little at 2-3000 rpm. Possibly an overactive knock sensor?
Any way to check its working/not giving false positives to the ECU?
Id rather not have to take it out if i dont have to as ive heard theyre easily breakable and are in an awkward place
cheers
Old Sep 2, 2014 | 02:44 AM
holmesnmanny's Avatar
Knock sensors rarely go bad. Odds are its the egr ports that need a good cleaning.
Old Sep 2, 2014 | 03:04 AM
Default Re: Knock sensor?
egr has been blocked off with a gasket that stops flow. EGR is still connected (however disconnecting it throws no code after a 15 min drive either)
I plan to clean ports and re instate EGR at some point but this problem occurs with EGR completely blocked off.
Old Sep 2, 2014 | 05:45 AM
Egr blocked off but still using stock ecu could cause the issues you are experiencing.
Old Sep 2, 2014 | 11:27 AM
why would his cause the hesitation at certain rpm?
Old Sep 2, 2014 | 02:13 PM
Egr works from 1500-3000 rpms. A stock ecu would think the egr is working and would allow egr gas to push through but with it blocked off it would have the wrong fuel map. Look at the ecu and report back what the ecu number is.
Old Sep 5, 2014 | 10:03 PM
cleaned egr ports, seems to be accelerating nicely now. wasnt too clogged but probably enough to cause dodgy running. just paranoid about getting brass swarf in the inlet from removing the plugs. think i got most of it though
all_motorsi
May 6, 2007 08:55 PM
InEK
20
Apr 10, 2006 09:03 PM
ninkei
Nov 15, 2005 04:45 PM
dav3ddt
Jul 7, 2004 06:37 AM
machine4321
Aug 20, 2003 06:03 AM
