knock sensor
Old Mar 22, 2007 | 02:27 AM
Playa_FL's Avatar
Default knock sensor
Does the car need that in order to operate, or will it cause it to not run correctly? Will it at least be drivable until I can get one? Does anyone have one they can sell me? I need one by tomorrow. I'm desperate. Thanks for any help guys.
Old Mar 22, 2007 | 04:39 AM
JimBlake's Avatar
Default Re: knock sensor (Playa_FL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Playa_FL &raquo;</TD></TR><TR><TD CLASS="quote">Does the car need that in order to operate, or will it cause it to not run correctly? Will it at least be drivable until I can get one? Does anyone have one they can sell me? I need one by tomorrow. I'm desperate. Thanks for any help guys.</TD></TR></TABLE>No a '79 Accord doesn't need that to operate.
Some years it's different, but for MOST Hondas the story goes like this...
The cars that even HAVE a knock sensor at all, are the ones that are designed to use higher octane. Most Accords use regular so they don't have a knock sensor.
Then, the knock sensor's main purpose is to detect knocking so the ECU can pull back the spark timing. Without the protection of a knock sensor, you should make SURE you're using fuel with AT LEAST your minimum octane requirement.
If you have higher-than-stock compression ratio, or if you've advanced your spark timing more than stock; then you should be more careful with fuel choice until you get your knock sensor replaced.
Old Mar 22, 2007 | 08:25 AM
Playa_FL's Avatar
Default Re: knock sensor (JimBlake)
Thanks!
95BoostedEJ1
10
Nov 23, 2007 10:51 AM
Leviata-N
Mar 13, 2006 11:36 AM
Team 4
Aug 4, 2004 04:53 PM
