jwogen1's general info for Accords
Old Mar 13, 2004 | 12:39 PM
jwogen1's Avatar
Default jwogen1's general info for Accords
just some basic info most of us know, but may be helpful.
1st generation accords: 1976-1981
2nd generation accords: 1982-1985
3rd generation accords: 1986-1989
4th generation accords: 1990-1993
5th generation accords: 1994-1997
6th generation accords: 1998-2002
7th generation accords: 2003+
(Trim and equipment levels range from DX, LX, LXi, EX, EX-R, SE, SEi, V-6)
-these include canadian models
Engine Identification(year/model, engine displacement, engine series, fuel system, engine type)
2nd Gens
1984 Accord: 1.8L(1829cc), ES2, 3bbl, SOHC 12-valve
1985 Accord: 1.8L(1829cc), ES2, 2bbl, SOHC 12-valve
1985 Accord SEi: 1.8L(1829cc), ES3, 2bbl, SOHC 12-valve
3rd Gens
1986 Accord: 2.0L(1955cc), BS, 2bbl, SOHC 12-valve
1986 Accord LXi: 2.0L(1955cc), BT, EFI, SOHC 12-valve
1987 Accord: 2.0L(1955cc), A20A1, 2bbl, SOHC 12-valve
1987 Accord LXi: 2.0L(1955cc), A20A3, EFI, SOHC 12-valve
1988 Accord DX/LX: 2.0L(1955cc), A20A1, 2bbl, SOHC 12-valve
1988 Accord LXi: 2.0L(1955cc), A20A3, EFI, SOHC 12-valve
1989 Accord DX/LX: 2.0L(1955cc), A20A1, 2bbl, SOHC 12-valve
1989 Accord LXi: 2.0L(1955cc), A20A3, EFI, SOHC 12-valve
4th Gens
1990 Accord DX/LX: 2.2L(2156cc), F22A1, MPFI, SOHC 16-valve (single exhaust manifold)
1990 Accord EX: 2.2L(2156cc), F22A4, MPFI, SOHC 16-valve (dual exhaust manifold)
1991 Accord DX/LX: 2.2L(2156cc) F22A1, MPFI, SOHC 16-valve (single exhaust manifold)
1991 Accord EX: 2.2L(2156cc), F22A4, MPFI, SOHC 16-valve (dual exhaust manifold)
1991 Accord SE: 2.2L(2156cc), F22A6, MPFI, SOHC 16-valve (dual intake manifold)
1992 Accord DX/LX: 2.2L(2156cc) F22A1, MPFI, SOHC 16-valve (single exhaust manifold)
1992 Accord EX: 2.2L(2156cc), F22A4, MPFI, SOHC 16-valve (dual exhaust manifold)
1992 Accord EX-R: 2.2L(2156cc), F22A6, MPFI, SOHC 16-valve (dual intake manifold)
1993 Accord DX/LX: 2.2L(2156cc) F22A1, MPFI, SOHC 16-valve (Canadian models: LX/EX)
1993 Accord EX/SE: 2.2L(2156cc), F22A6, MPFI, SOHC 16-valve (Canadian models: EX-R/SE)
5th Gens
1994 Accord EX: 2.2L(2156cc), F22B1, MPFI, SOHC 16-valve (Canadian models: EX-R)
1994 Accord DX/LX: 2.2L(2156cc), F22B2, MPFI, SOHC 16-valve (Canadian models: LX/EX)
1995 Accord EX: 2.2L(2156cc), F22B1, MPFI, SOHC 16-valve (Canadian models: EX-R)
1995 Accord DX/LX: 2.2L(2156cc), F22B2, MPFI, SOHC 16-valve (Canadian models: LX/EX)
1995 Accord V-6: 2.7L(2675cc), C27A4, MPFI, SOHC 24-valve
1996 Accord EX: 2.2L(2156cc), F22B1, MPFI, SOHC 16-valve
1996 Accord DX/LX: 2.2L(2156cc), F22B2, MPFI, SOHC 16-valve
1997 Accord EX: 2.2L(2156cc), F22B1, MPFI, SOHC 16-valve
1997 Accord DX/LX: 2.2L(2156cc), F22B2, MPFI, SOHC 16-valve
obviously need more general FAQ info in here, so feel free to post and i will update. I stopped short of 6th and 7th gens, as well this is just a start to general info. not sure where we would like this to go, and please fill in any blanks and info to add.
Also, this should probably be combined with VRDrvr's thread, so keep that in mind when reviewing both
Modified by jwogen1 at 4:51 PM 3/13/2004
Modified by jwogen1 at 10:10 PM 3/13/2004
Old Mar 13, 2004 | 11:40 PM
.bagged's Avatar
Default Re: jwogen1's general info for Accords (jwogen1)
Great addition to the FAQ..this thing is going to be huge
Old Mar 16, 2004 | 02:21 PM
jwogen1's Avatar
Default Re: jwogen1's general info for Accords (baGged93aCcord)
this is always handy...I found this link on H-T somewhere, so not trying to take credit for this but it is a great piece. http://www.extremeredline.net/....html
AUTO to MANUAL SWAP SECTION
Parts List:
1. 5 speed transmission (F22, F23, H22, H23)
2. 5 speed starter (90-02 Accord 92-02 Prelude)
3. 5 speed shifter assembly w/ shifter cables (90-97 Accord 92-96 Prelude)
4. 5 speed drivers side axle (your year accord, but from 5-spd version)
5. 5 speed intermediate shaft (your year accord, but from 5-spd version)
6. 5 speed clutch pedal assembly (90-97 Accord 92-96 Prelude)
7. 5 speed brake pedal arm (90-97 Accord 92-96 Prelude)
8. Clutch master cylinder w/ reservoir (90-97 Accord 92-96 Prelude)
9. Clutch line from Clutch master cylinder to clutch dampener (90-97 Accord 92-96 Prelude)
10. Clutch dampener assembly (90-97 Accord 92-96 Prelude)
11. Clutch line from Clutch dampener to 5 speed tranny (90-97 Accord 92-96 Prelude)
12. Clutch line from 5 speed tranny to slave cylinder (90-97 Accord 92-96 Prelude)
13. Slave cylinder (90-97 Accord 92-96 Prelude)
14. Clutch (90-02 Accord 92-01 Prelude)
15. Flywheel (90-02 Accord 92-01 Prelude)
16. 5 speed mount (Your year, 5-spd version)
17. 5 speed mount bracket (go to honda - tell them to look for the bracket that is welded on the car - part is S.O.P and costs 15-25.00) (see notes)
18. MIG WELDER (see notes)
19. BOLTS: 8 Flywheel Bolts, 6 Pressure Plate Bolts, 3 Intermediate Shaft Bolts, 1 Long Tranny Bolt
20. Recommended: HELMS Service Manual (www.helminc.com) CHILTONS Manual
Disconnect the battery. Remove it, the battery tray and the air intake to gain working room. (Distributor helps also) Raise the front of the car up in the air, support it on jack stands and remove the front wheels. Drain auto transmission fluid. Remove the axle nut (36mm). (note: this nut is at 180 lb-ft, the best way to remove the bolt is to put an extension pipe on the socket wrench you are using, works great, have someone stomp on the brakes as you loosen it) Remove the lower ball joint cotter pin and nut (17mm) on both sides. Take a floor jack and start to raise the car up on the lower knuckle so the ball joint pops out. When it does remove the axles. To pry the axles from the tranny, insert a decent size flat head screwdriver in-between the axle and the tranny, then just pop it. It will pop out of socket, then you can pull it out the rest of the way. Be sure to keep pressure on the ends of the axles because if the cv joints come apart its not fun putting them back together. Remove the passenger side radius rod (suspension piece right under the tranny) When that's done start removing the wire harnesses connected to the tranny. Remove the starter from the tranny. Remove the torque converter cover and the tranny cable from underneath the tranny. Now you have to remove each of the 8 bolts that hold the torque converter to the flex plate. This is done 1 or 2 at a time, and then you must rotate the crank to get to the next couple. Make sure you have something holding the tranny (jack or lift) Remove the tranny bell housing bolts and remove the tranny mount. Drop the tranny slowly. Be careful because it's heavy. Remove the 8 bolts holding the flex plate to the block. They are 17 mm 12 point sockets. Then bolt up the flywheel using the NEW bolts you got, because the flex plate bolts are too short.
Remove the center console in the car, disconnect the shifter assembly and the cables attached. Remove the brake pedal arm (there is a spring at the top - keep it) remove the plate that's covering the clutch master cylinder access. Take up passenger side carpet and remove the a/t control unit Unplug it - you don't need it anymore. Replace the ECU with the 5-speed version at the same time.
Bolt all the hydraulic lines linking the clutch master cylinder to the tranny, then to the slave cylinder.
(Cut off the old tranny mount before putting the new tranny into the engine bay.)* Install the tranny in reverse order of removal. Weld the 5 speed tranny mount onto the car. Then run the shift linkage cables from the inside of the car to the top/rear of the tranny. Connect these where they belong and put the cotter pins on to keep them on the right places. Install the old auto passenger side axle and the new intermediate shaft into the tranny. Bolt the intermediate shaft hanger to the block using the new bolts. Then install the new drivers side axle. Put the axles into the hubs and reinstall the balljoint that was taken apart. Then have your friend stand on the brakes again so you can tighten the axle nuts. Install the new manual tranny starter. You will need the long bolt that goes through the starter then through the tranny and into the block. Connect the power cable to the starter and the ground cable to the tranny. You might have to pull the clips off of the cables to get them to reach, no biggie.
Wiring:
Method 1: Now its time to make the car start, first off start by taking the 2 nuts holding the white part on the automatic shifter and plug the 2 wire in that need to go where they belong (brown plug and a long white plug) Then tuck them in somewhere next - put in neutral and hope the car starts, if it does have fun you now have completed the impossible just to correct...
Method 2: I did not remove the a/t control unit, no need to, just extra time to do it. There is also some more wiring that I had to do, maybe because I didn't pull the computer, not sure. When you pull the auto shifter assembly, there will be 4 or so harnesses left laying there. On one harness (on the drivers side, I think it was the biggest connector on that side) I connected pin # 2 (green) to pine #5 (counting sraight accross, left to right) brown or black, not sure, its a ground I think, and the other harness I had to modify was also on the drivers side of the shifter assembly, its two bigger guage wires, I just connected them together. These two harnesses control the kill starter (makes sure car is not in gear when you start it) and the other makes it so you can take your keys out of the ignition, basically, I tricked the computer into thinking it is always in park.
Notes:
Mounts #1: I did not have to modify any mounts, but I used a 94 H23 tranny and motor when I did mine, not the accord tranny. The only modification I had to make to the engine bay was the rear support beam, I had to grind off about 1/2"X1.5" so this little bracket/bolt thing wouldn't hit it, nothing a grinder didn't take care of.
Mounts #2: I put my H23 tranny in with a F23A1 engine and did not need to modify any mounts. Of course the engine was a little off to the drivers side, and there were some clearance issues. But those were solved with some trimming of the crank pulley and the absence of A/C.
Mounts #3: The mount on the 5th gen Accords is the same for the manual and automatic versions so no modifications are required.
Disclaimer:
The people who wrote this, and presented this information are in no way responsible for your actions. You perform these modifications at YOUR OWN RISK. If you are not capable of doing these things, let someone else do it for you.
Old Mar 16, 2004 | 02:22 PM
fw190bvi's Avatar
wow....this will HAVE to go in teh DIY/Install section.........
Old Mar 16, 2004 | 02:26 PM
.bagged's Avatar
Default Re: jwogen1's general info for Accords (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">wow....this will HAVE to go in teh DIY/Install section.........
Is DIYaccord doing that section?
jwogen1's Avatar
i figured it would be a great addition for our FAQ sticky thread
Old Mar 16, 2004 | 02:28 PM
fw190bvi's Avatar
i nominated him.....but i dont think it ever got around to him......bagged, wanna send him a PM??....im too lazy
Old Mar 16, 2004 | 02:30 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">i nominated him.....but i dont think it ever got around to him......bagged, wanna send him a PM??....im too lazy</TD></TR></TABLE>
Got it...lazy ***..
Old Mar 16, 2004 | 02:35 PM
fw190bvi's Avatar
HEY.....ive got calc homework to do...so back off.....lol
BTW, weve totally whored out this thread for use of FAQ Page discussion.......again
Old Mar 16, 2004 | 02:43 PM
jwogen1's Avatar
isnt it great--i love it
Old Mar 16, 2004 | 02:45 PM
urbanlegend21's Avatar
New User
moved all info to the already created thread.....
if there is more info to be added please IM me and I will unlock that htread
slayerfromhell212
Dec 29, 2006 10:41 PM
Rishiras
Mar 2, 2006 02:50 PM
rolledthatho
Sep 2, 2005 11:06 AM
d15civ
Nov 19, 2004 06:11 PM
AngryTroll
Aug 23, 2004 07:46 AM
