just bought a 97 Accord EX with 96k but it needs work...
hey, new to this forum,
-i just bought a 1997 honda accord Ex with 96k on the engine for about 2k less than what it is bluebooked at. the car itself is in great condition, there are virutally no dings or dents, everything is clean and new and all the ammenities (sunroof, cd player, power windows, etc) all work. the most glaring problem is the actual driving smoothness of the car. between first and second gear the car seems to jump or lurch and i hear a dampened popping sound coming from the undercarrage. its most definetly the transmission but i want to know what kind of money am i going to have to throw at this thing. i am pretty sure the tranny does not need to be replaced but i am not sure what exactly is wrong with it.
-also, seeing as how its a 96k car and the previous owner was an old lady, the timing belt is going to need replacing. how much am i looking to spend there, all said and done?
-the idle is rough. sitting at a light the whole car shakes. what causes that and what can I (me) do to fix it?
-it has an aftermarket exhaust. how much is it going to cost to have it removed and a stock one installed? can i then sell it?
-there is a repetitive squeaking noise when i turn the ac on at idle. like a gerbil running on a wheel. is there a quick fix for that (lube something?) or do i have to have a pro look at it
im not looking for exact figures here just ballpark figures. any suggestions would be appreciated. of course i would love to do these repairs myself so tell me if that is even an option.
Re: just bought a 97 Accord EX with 96k but it needs work... (ROCKART)
an old lady with an after market exhaust? exhaust will probably be <$500 if you want a stock one put on at a honda dealer.
Re: just bought a 97 Accord EX with 96k but it needs work... (chuckgregory)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuckgregory »</TD></TR><TR><TD CLASS="quote">an old lady with an after market exhaust? exhaust will probably be <$500 if you want a stock one put on at a honda dealer.</TD></TR></TABLE>
I was thinking the same thing about the old lady with the exhaust. Maybe her grandson or something.
Re: (Turboduck)
The full timing belt job (t-belt, water pump ect.) should run you 500-700 depending on where you go. If you are up for doing it yourself there are a few good write-ups on this site just use the search feature.
EDIT: Sorry, a jumping and lurching is definately a problem. Carry the car to Aamco. Go on their website and print out their coupon for a free transmission check and go to them and see what they say about it. They will just drive the car, but they should know what it should feel like.
A used transmission is about $250-$300. Check out your local junk yard or http://www.car-parts.com . You could try changing the transmission fluid. If it hasnt been changed regularly, that could have been the issue. I think there is a certain transmission fluid that I always hear recommended which helps a dieing trasnmission. I am not sure if it is GM readline or something like that. I know Honda ATF is pretty good though.
When you are doing your timing belt change, they will change the A/C belt and the power steering belt as well. They are about $12 each. If you are handy, you could probably just change them yourself. About an afternoon of work if you are doing it for the first time.
You are in Florida. Everything is cheaper in Florida. I took my car to get it tinted in Florida. I paid $45, where as up north, I would have paid $120-$150. I had my car interior detailed $35 with 4 guys working on it at once, up north, I would have paid $100-$150.
Silvertune
02-20-2013 05:10 PM
RMC_SS_LDO
05-31-2011 12:22 PM
tech125B
03-27-2007 07:42 PM
Jeff Lawrence
06-24-2003 12:57 PM
