Ignition problem/question
Old Oct 10, 2004 | 10:36 AM
S0ld1er's Avatar
Default Ignition problem/question
I have a 92 Accord Ex and recently the ignition crapped out on me. I'm not sure if this is a common problem with Accord so I guess what I am here to ask is: What are the common malfunctions with the ignition system? I don't want to go through the hastle of replacing the entire ignition when all I might need is a new cylinder.
Any help is appreciated, thanks.
Old Oct 10, 2004 | 06:13 PM
KatyHonda's Avatar
Default Re: Ignition problem/question (S0ld1er)
First, how do you know it's definitely ignition?
Common ignition problems are cracked rotor, bad coil, bad ignitor, faulty ignition switch, in no particular order.
good luck
Old Oct 10, 2004 | 07:08 PM
hawkmgc's Avatar
Default Re: Ignition problem/question (KatyHonda)
Most of the time with a no spark it ends up being the coil. Depends on which distrib. system you have. If the coil is internal its usually that. If its external then it ends up being either the Ignitor or ignition wire.
If it was a cracked cap then you would have had problems in the past with water when it rained or on a cold night where there is dew on your windshield.
Old Oct 10, 2004 | 07:22 PM
cmrvi1's Avatar
Can you describe exactly what your car is doing??
Old Oct 11, 2004 | 05:28 AM
Desslok's Avatar
Default Re: Ignition problem/question (cmrvi1)
My 92 was the igniter. Luckily mine was replaced by the dealer as it was covered by a silent recall at the time. They no longer honor the recall and seem to have "forgotten" about it. Are you sure you have no spark?
Old Oct 11, 2004 | 09:06 AM
br'Y'an's Avatar
i have the same problem its your Distributor (2 sensors are messed up) inside the Distributor
Modified by beatjunkie42 at 10:24 AM 10/11/2004
nanagsr
Jun 24, 2009 07:04 PM
chahsiubow
Jul 12, 2005 05:38 PM
TheHatchHog
Aug 9, 2003 07:04 AM
magic hat #9
Dec 31, 2002 06:53 PM
