Which Ignition?
Old Jun 3, 2002 | 10:06 PM
macswhtaccord's Avatar
Default Which Ignition?
Which is the better ignition between Crane Cams and MSD? I will be running a 75 shot of n20.
Old Jun 4, 2002 | 04:58 AM
carolinaACCORD's Avatar
Default Re: Which Ignition? (macswhtaccord)
i say MSD, they are the top dogs of the ignition market.
Old Jun 4, 2002 | 05:03 AM
SOHCArchangel's Avatar
Default Re: Which Ignition? (carolinaACCLUDE)
i have been running a 6al for 4+ years, and a blaseter ss external coil
Old Jun 4, 2002 | 05:08 AM
i've also heard of quite a few people using jacob's, but i dont really know if it's any good or not.
Old Jun 4, 2002 | 05:19 AM
ive heard mixed views on jacobs......
and i know someone who was not satisfied with the crane ignition at all
Old Jun 4, 2002 | 05:31 AM
John's Avatar
New User
Personally, I'd stick with the OEM ignition. Save your money and invest it elsewhere.
Old Jun 4, 2002 | 05:48 AM
Default Re: Which Ignition? (DunReit)
i kinda feel the same, unless your car is heavily modded, because a complete ignition would cast around what $300?more or less.
that's $300 you could spend on more nitrous goodies.
Old Jun 5, 2002 | 08:21 PM
Oh I thought that you really needed one for timing retard, and a more complete combustion, smooth idle etc.
Old Jun 5, 2002 | 11:25 PM
FastechAccord's Avatar
I believe DunReit is completely retarded. You have to have an aftermarket ignition to run a 75 shot of n20. You need an ignition that allows you to retard your timing such as the msd digital 6.
Old Jun 5, 2002 | 11:28 PM
Accord94DX's Avatar
Default Re: Which Ignition? (EvoAccord)
You can retard the ignition without the aid of a msd.
Old Jun 6, 2002 | 01:10 AM
Brandon's Avatar
Life is Suffering
Default Re: Which Ignition? (Accord94DX)
The Accel Thundersport 300 ignition is pretty good. They know their stuff when it comes to sparks.
Old Jun 6, 2002 | 08:06 AM
Eddiebx's Avatar
Yah thats true, but maybe he's OBDII? I think, all OBDII cars have locked timing. I konw my 6th gen V6 its locked, also on my boys 5th gen Lude. So in that case you need to get an aftermarket timing controller.
Eddie
Old Jun 6, 2002 | 08:08 AM
What do you guys think about the Crane Fireball or Hi-6 ignition?
Old Jun 6, 2002 | 08:14 AM
John's Avatar
New User
Is that so? Well, I've never had a problem with my OEM ignition, and I'm coming up on 3 years of using nitrous (75 shot) on my car. If you gap your spark plugs right, and keep your spark plugs fresh, then you should have no problem at all with the OEM ignition.
Old Jun 6, 2002 | 08:15 AM
Accord94DX's Avatar
Default Re: Which Ignition? (Eddiebx)
Eddie
Uh....no. Im sorry, you are incorrect. You can still adjust the timing on an obd2 car by jumping the service connection and turning the distributor.
Old Jun 6, 2002 | 09:57 PM
You cant turn the distibutor on a 96-97 accord, they have locked distributors. The ECU does all the timing adjustments. Dunreit, you are lucky as hell you havent burnt valves or detonated with no retarding of your timing. Plus, it is recommended to retard your timing 3 degrees with a 75 shot. An adjustable distributor only lets you retard your timing 2 degrees.
Old Jun 6, 2002 | 10:07 PM
Accord94DX's Avatar
Jesus christ.....
Old Jun 7, 2002 | 04:51 AM
John's Avatar
New User
Retarding your cam timing also retards your ignition...
Old Jun 7, 2002 | 04:54 AM
uh...uh...ok i also have a 75 shot and guess what.....factory ignition.
and yes, i have a 96 accord and guess what, yes you can turn the distributor to adjust timing.
Old Jun 7, 2002 | 06:58 AM
Eddiebx's Avatar
Oh, dunno about them 96-97 accords, just know that my V6 is locked and so is my friends 5th gen lude.
Eddie
Old Jun 7, 2002 | 09:02 AM
2point6's Avatar
... An adjustable distributor only lets you retard your timing 2 degrees.
WHAT??? Man, now I am really screwed...
Old Jun 7, 2002 | 09:33 AM
smokin rubber's Avatar
Default Re: Which Ignition? (2point6)
ha
Old Jun 7, 2002 | 10:35 AM
KTeller8's Avatar
Default Re: Which Ignition? (smokin rubber)
my timing is off. and i tried to tune it. but i couldnt cause it wouldnt let me move anythind and tighten it.. my freind had to cut the lower part of his to move it along the bottom screw..
MSD 6BTM is one of the best to get though.. you can pick one up off ebay for around 225-250 and they run around 400 normally..
PGT Driver
Aug 20, 2006 12:50 PM
SB97civic
10
May 17, 2004 07:49 PM
96LudeSiVTEC
Feb 23, 2003 11:54 AM
auto-gs-king
Jan 28, 2002 12:29 AM
