Idle Problems
Old Aug 8, 2014 | 07:58 AM
Slammed_Accord's Avatar
Icon3 Idle Problems
So I have a 98 Accord ex I4, and when it idles the rpms jump from 1000-1500 then back down, then back up and that keeps going on and on and on. Its not just the tach because the engine itself is revving. Any mystical wisdom? I've already taken off my IACV and cleaned it out.
P.S. I'm a new member, so I'll post a video when I can.
Old Aug 8, 2014 | 10:56 AM
jmanuel's Avatar
Default Re: Idle Problems
Had the same problem but for me I had to replace the iacv. Iwas told that air could be trapped in the cooling system that you should try to bleed it out.
Old Aug 8, 2014 | 11:52 AM
I've already bled the coolant. How much does an IACV run for? Should I check local scrap yards or do I have to buy new?
Old Aug 8, 2014 | 12:10 PM
jmanuel's Avatar
Igot min from oriellys for $150 but if you know of one being parted out that would probably be better. If you take off your air duct assembley there'll be a small port that leads to the iacv.. If you cover it with a rag and the idle drops down to normal its most likely the iacv but if the idle continues to bounce around its probably a different cause or air leak
Old Aug 8, 2014 | 06:58 PM
Ronsonic's Avatar
Have you ruled out low tech, old fashioned vacuum leaks?
bacuh
Jun 13, 2015 02:46 PM
VTechLivin94
15
Mar 29, 2013 06:52 AM
mkrieger500
Mar 2, 2011 12:53 PM
ls19integra95
Mar 12, 2008 04:40 PM
accord9t3
Nov 20, 2004 02:17 PM
