Idle problem.
Old Oct 15, 2007 | 03:48 PM
Tu_Sae's Avatar
Default Idle problem.
I know, I know. read the threads. But I haven't found anything that's what I'm looking for. Just started happening today. When my a/c turns on, cars idles down and wants to shut off. Someone told me that there is a sensor that is supposed to prevent this from happening. is this true?
Old Oct 15, 2007 | 05:17 PM
JimBlake's Avatar
Default Re: Idle problem. (Tu_Sae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tu_Sae &raquo;</TD></TR><TR><TD CLASS="quote">I know, I know. read the threads... is this true?</TD></TR></TABLE>Yes, read the threads.
Actually, you need to tell us exactly what type of car you're talking about. There's about 30 years of Accords, & they're not all the same.
Read the threads about cleaning your IACV & FITV. That's the basic issue for your problem. Unless your car is too old. Or too new.
Old Oct 17, 2007 | 11:51 AM
Tu_Sae's Avatar
Oops, it's a 92 Honda Accord EX. I have searched, but I dont' get what I'm looking for
Old Oct 17, 2007 | 05:57 PM
JimBlake's Avatar
Default Re: (Tu_Sae)
Maybe in '92 there's something specific for the AC load. I know there's a device over on the left end of the intake manifold that may also be involved in that system.
On the newer cars I know about the ability to hold a steady idle with AC is part of the overall idle control system. So in that case you'd want to clean the IACV & properly set your base idle.
The system has components that work together. If someone simply tries to adjust the idle, the other components fight against each other. It's particularly bad if a misguided mechanic tightens the throttle cable to bump up the idle.
Here's a good thread.
https://honda-tech.com/zerothread?id=1844067
Read it all. Especially a post by ME about how to set your base idle.
banjuju
May 10, 2007 05:34 AM
redboost10
Jan 20, 2007 02:22 PM
PinoyCivic
Jan 10, 2006 10:38 AM
..::91TEG-G2::..
Jan 26, 2005 10:01 AM
TypeRPaul
May 21, 2004 05:43 PM
