how to remove dash?
Old Aug 28, 2002 | 11:04 AM
4doorH22's Avatar
Default how to remove dash?
Search no good.
4th/5th gen should be pretty much the same. Helms says steering column needs to be undone and dropped to remove the entire dash.
The whole job seems easy enough I'm just not sure if I have to lower the steering column or not. Anyone removed their entire dash? Does the steering colum need to be undone?
Thanks
Old Aug 28, 2002 | 11:20 AM
smokin rubber's Avatar
Default Re: how to remove dash? (4doorH22)
you are crazy
I took the black front panel and center consule out to install my tach, and that was a major pain. Why do you want to do this?
Old Aug 28, 2002 | 05:16 PM
CD8's Avatar
CD8
Default Re: how to remove dash? (smokin rubber)
prolly to just weigh his car down with MORE dynamat
[Modified by exaccord, 6:16 PM 8/28/2002]
Old Aug 28, 2002 | 05:24 PM
4doorH22's Avatar
Default Re: how to remove dash? (exaccord)
Nah I can do that from the footwells.
I was thinking of installing a very hard to get to alarm and lojack or something
Old Aug 28, 2002 | 05:25 PM
Brandon's Avatar
Life is Suffering
Not worth it.
Old Aug 28, 2002 | 06:52 PM
louder160's Avatar
Default Re: how to remove dash? (F22turbo)
I don't think I would waste my time. Most of the wires that you will need for the alarm including your ignition and starter wires are in your kick panel anyways.
Old Aug 28, 2002 | 09:26 PM
GimpyAccord's Avatar
Default Re: how to remove dash? (louder160)
yah, after spending 2 summers of my life installing i can tell you thats a big waste of time. just put it around the cruise control unit like everyone else... best you can hope for is an amatuer thief and/or hear it go off anyway. if you wanna hide something hide a fuel cutoff switch or relay. i treat alarms like keyless entry systems that happen to beep now and then.
i took out my dash once to fix a couple melted wired i couldnt get to, and i thought i did a good job and had a couple screws left over and ever since the dash has rattled a lil .. leave it in
we also installed lojacks, which was handled by a special guy.. in theory even you arent supposed to know where it is. I had one put in my 1995 GSR and i found it in 3 minutes.. he put it in the area between the rear folding seat/body. .... that car was stolen in 1998 and recovered a chopped up shell in 4 days ... was not worth the 500.00 and i got screwed on their guarantee because i stupidly said i even knew where it was and they blamed me for it 'not working'
[Modified by GimpyAccord, 6:36 AM 8/29/2002]
Old Aug 28, 2002 | 09:54 PM
Conechaser's Avatar
Default Re: how to remove dash? (GimpyAccord)
to answer your question, yes, you do have to drop down the steering column, but it is no big deal, just to nuts you have to take off and it will drop down to a lower perch, thats the easy part. The hard part is getting the wiring harness out of the dash, THEN putting it back in.
Old Aug 29, 2002 | 09:27 AM
4doorH22's Avatar
Default Re: how to remove dash? (94Accord)
Okay thanks. I figured the dash looks pretty easy in the Helms (have you noticed the Helms sometimes lists steps you don't have to do?). I am essentially "restoring" my car and was gonna poke around under the dash for the hell of it, but if the harness is a PITA I think i'll forget it.
89crxhf
12
Oct 7, 2012 09:18 PM
95_Civic_4dr
Jan 28, 2009 10:22 PM
DrGrEeNtHuMb
Apr 5, 2008 04:39 PM
yOnKiNaToR
Jul 17, 2007 04:12 PM
projectcrx
Apr 26, 2002 04:25 AM
