P0325 knock sensor 2000 accord 4 cylinder
It's my brother's car and I only see it about once a month so I haven't looked into it too far.
But the original issue was the P0325 code for the knock sensor, car seemed to drive fine otherwise. I put a new amazon/ebay knock sensor in and sent him on his way but a few days later the code came back.
I looked at it again today and noticed that it seemed to idle fairly low especially when turning the steering wheel. Is this issue and the code related? Is it idling low because of a knock sensor fault? Or is it getting a knock sensor fault because it's idling low?
Re: P0325 knock sensor 2000 accord 4 cylinder
YOU EVER FIX THIS ??! Mines doing the same code and IS NOT LETTING ME GO PAST 30mph the car cuts off and idles low when coming to a stop but motor and everything is good in park and neutral…
Yeah, I fixed it. The idle issue was unrelated but I ended up needing an actual OEM knock sensor, not an ebay knock off. I snagged one from the junkyard and put it in and the light went off right away.
