Honda supreme engineering design
Old 01-25-2016, 09:31 AM
Digitalis's Avatar
Default Honda supreme engineering design
my carpets has been wet recently after the rain, so I tore into my car
I am missing something here? why the duck would u put a sunroof drain inside the car?
Old 01-28-2016, 11:38 AM
masospaghetti's Avatar
Default Re: Honda supreme engineering design
Your picture didn't load for me, but obviously this isn't by design.
Old 01-30-2016, 07:29 AM
poorman212's Avatar
Not sure of the question/issue and the picture is too small for my old eyes.
The drain tube should be connected to a drain valve that lets the water flow outside the car.
Old 01-30-2016, 07:34 AM
Digitalis's Avatar
I'm not sure how to make the picture bigger.
However, the drain tube just comes out a little higher than my electrical cluster by the fuze box.
There was nothing attached to it, and when I poured water into my drain channel, the water would pour out from the tube.
I've put a piece of nylon tube and extended it, but I was not aware there was supposed to be a drain valve.
Old 01-30-2016, 08:07 AM
poorman212's Avatar
Look around the area and you should find a "black tube" - that is the drain "valve" I was talking about.
This is for a 6th gen and on the pass side but Honda hasn't changed the design/concept in a long time......my 3rd gen(s) had the same design/concept.
https://honda-tech.com/honda-accord-...nroof-3135265/
mcd7
01-21-2012 11:33 AM
milanoredgsr
02-24-2008 11:14 AM
pcorad
07-04-2005 07:40 AM
TypeRuz
11-19-2003 07:57 AM
OgunplayGSR
07-12-2002 10:12 PM
Quick Reply: Honda supreme engineering design
