help with trans problem?
Car shifts fine in all gear except for 3rd. There is a slight grind going into 3rd gear.
I can down shift into third with no grind just fine. While driving from 1st up, to avoid the 3rd gear grind, I go from 2nd into 4th back into 3rd and there is no grind. There is only grind when I go from 1st to 3rd or 2nd to 3rd.
any solutions? Motor is a h22a 5 speed
Be sure that someone hasn't put 80w90 oil in the trans, should have 10w30 in it or Honda MTF.
Beyond that..... yank the trans and install new syncros
