help! running a code 4
Old May 12, 2014 | 08:04 PM
gamajohn's Avatar
Default help! running a code 4
Ok so I recently purchased a 95 accord from my buddy. He had the car for a while it ran great until the camshaft broke on him. I told him I'd buy the car from him and i just replaced the head. Put everything back together tried to adjust the valves the best I could. It was a bit more complicated on the accord than my civic. And the timing belt as well with the balance shaft belt. Started right up but idles poorly. The car seems to me missfiring on cylinder 1 because I noticed my timing light didnt have a consistent flicker and sometimes it would even cut off for a second. I took it on the highway it ran a code 4. Went home adjusted some more things now it's a code 4 and 22. Any clue as to what I did wrong? What causes a code 4? Timing was excellent and even the marks lined up good for the ignition timing. Could the distributor just be bad? It ran fine when he had it before the camshaft broke.
Old May 12, 2014 | 08:06 PM
gamajohn's Avatar
Default Re: help! running a code 4
Also it only runs a code when I get on it. And it's slow on acceleration
Old May 12, 2014 | 08:08 PM
gamajohn's Avatar
Oh and I did notice when the light gun did have a consistent flicker it ran smoothly
Old May 12, 2014 | 10:00 PM
NerfGunner420's Avatar
do a leakdown test? is the head rebuild? or just a junkyard head? valves might not be adjusted right, too tight and it will just hang open enough to let some compression out
Old May 12, 2014 | 10:01 PM
5 MAP - manifold absolute pressure sensor
22 VTEC pressure valve
check them both
Old May 13, 2014 | 06:47 AM
gamajohn's Avatar
Yes the head is rebuilt. Has new valves springs and cam. I checked the spacings on the exhaust side this morning and they seemed perfect. It seems to me it's electrical. Is there a ground wire I missed? On my civic there's one on the thermostat housing. Where it that at on the accord?
Old May 13, 2014 | 09:13 AM
http://www.bing.com/images/search?q=...electedIndex=2
good luck
Old May 13, 2014 | 01:21 PM
holmesnmanny's Avatar
code 4 is crank position sensor in the distributor ...swap out the distributor
code 22 is vtec pressure switch ... check for any dents in the oil pan that could be restricting oil flow .. clean the vtec solenoid screen
dietpepsi#1
Jul 25, 2013 08:12 PM
Bh8teen
Aug 31, 2005 09:26 PM
civic_dork
Jul 3, 2005 07:40 AM
