Help Please
Old Mar 29, 2004 | 08:45 AM
chopper's Avatar
Default Help Please
I need to replace some wheel lug nut studs on my '96 accord. They are stripped. Is this a DIY project?
Old Mar 29, 2004 | 09:59 AM
JimBlake's Avatar
Default Re: Help Please (chopper)
Front or rear (it matters)? What's the biggest DIY job you've ever done?
Some people have the tools to do this stuff. We don't know YOUR level of experience... Have you ever taken off a drive axle? Taken off a steering knuckle?
Old Mar 29, 2004 | 11:42 AM
chopper's Avatar
Default Re: Help Please (JimBlake)
I'm pretty handy. I do most of my honda maintinence myself. The studs are at the front wheel. Does the rotor need to come off?
Old Mar 29, 2004 | 12:18 PM
JimBlake's Avatar
I don't have a '96 so I don't know. But I just wanted to point out the missing information. My guess... the rotors have to come out.
In my '95 Integra there isn't enough clearance for the studs to come out the back of the hub. So the hub has to be pressed out of the wheel bearing. This usually destroys the bearing. If you like DIY but you don't have a press, you can take the steering knuckle assembly out & carry it to a shop. I'm guessing yours will be vaguely similar.
Hopefully someone with a '96 can say something???
Old Mar 29, 2004 | 01:28 PM
SearchBeforeUPost!'s Avatar
you are going to have to take off the hub assembly, screw a lug nut on the stud and pound with a BFH.
but to answer your question: yes, it is a DIY project.
Old Mar 29, 2004 | 01:36 PM
iam7head's Avatar
Default Re: Help Please (SearchBeforeUPost!)
you need to take out the rotor, brack caliper and all that stuff mount on the steering knuckle.
if the stud are stripped really bad, just wack it hard enough with a rubberized hammer.
the installation of stud is pretty simple, just use the lug to drive the stud into the mounting plate(what is that thing called again?)
b20vtecturbe
Suspension & Brakes
Feb 9, 2012 05:48 PM
civiccoupe94
Aug 16, 2008 08:06 PM
jchandler
Oct 18, 2004 06:50 AM
sugarloafpkwy
Aug 23, 2003 09:00 PM
