Help!! P0118 code
Old Jun 25, 2012 | 01:45 PM
Melony O'Harra's Avatar
Icon6 Help!! P0118 code
I joined this forum because I have a 1996 Honda Accord and my check engine light is on and brought up two codes P0300 and P0118, we just replaced the spark plugs, and are going to replace the thermostat but I keep getting told that the thermostat is not going to solve our coolant temp problem. My questions are...is this true, do I need to buy an ECT sensor? And when we replaced the spark plugs there was a bit of an excessive amount of oil in the housing, we plan on replacing the valve cover because we could tell that that is where the leak is but I need to know what's causing my honda to start when it wants to, not when it's told to. Is it the P0118 code? And if it's a temperature why hasn't my car overheated at all?
Very confused!
Old Jun 25, 2012 | 06:15 PM
Product_of_1991's Avatar
Default Re: Help!! P0118 code
First, what does each of those codes mean? second, buying the ECT sensor wont be expensive and would be completely worth it
Old Jun 26, 2012 | 08:02 AM
Okay the P0300 is a random misfire, and the P0118 code is engine coolant temperature. I've been reading up on both codes and found out that if the temperature isn't reading correctly, if the temperature sensor and/or thermostat is not working correctly it could cause a no start situation. I just took the car to the mechanic, I'm going to let them deal with it for the time being, only because my father insisted that his mechanic take a look at it. Thank you for your quick reply!
Old Mar 28, 2014 | 07:12 AM
Vic_Sutton's Avatar
[QUOTE=Melony O'Harra;47531683] Hi I recently purchased a 96 Honda accord with the same code(p0118). I have replaced the temperature sensor and the temperature switch to which no avail. I would really like to know what you have learned about this problem.
mkrieger500
Sep 26, 2009 07:09 PM
GSR-EG-92
13
Apr 17, 2009 07:32 PM
deercanbrack
May 14, 2008 03:49 PM
MPALUGHI
Jan 7, 2005 05:11 AM
