help needed
Old Mar 24, 2007 | 12:37 PM
liljestrand's Avatar
Default help needed
my car (91 honda accord) is acting up and im hoping you guys can help.
when i start the car it starts fine but the lock cylinder seems to "lock" up and its real hard to turn the car off
secondly whenever i push the clutch in it sounds like the starter is winding up and sometimes makes a awful sound kinda like when you go to start your car when its already running...
third the brake light is on like the e brake is activated
and none of my heater controls or defrost controls work
can anyone help...it would be greatly appreciated.
P.S. i had it lowered like a week ago if that makes any difference.
Old Mar 24, 2007 | 02:29 PM
Aahj's Avatar
Default Re: help needed (liljestrand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liljestrand &raquo;</TD></TR><TR><TD CLASS="quote">my car (91 honda accord) is acting up and im hoping you guys can help.
P.S. i had it lowered like a week ago if that makes any difference.</TD></TR></TABLE>
1) Make sure you are pushing the key in before you turn it back. Possible ignition switch going bad or you need a new key.
2) If it makes the sound when you engage the clutch, it sounds like possibly the release bearing is going bad.
3) If the brake light is on but the e-brake isn't engaged, that means that your brake master cylinder resevoir is low on brake fluid.
4) Check your fuses
good luck,
AJ
Old Mar 25, 2007 | 01:48 AM
Default Re: help needed (Aahj)
yeah you were right it was the ignition lock going bad and not returning back to just the on position
Old Mar 25, 2007 | 01:57 AM
v skippah 22's Avatar
you know ive also had this problem in my first accord it was a 1993 accord, same fix too my dad got it done without telling me, simple fix but just a little time consuming. try a new key first
19accord97se
Nov 18, 2014 09:52 AM
Sven_jb
Apr 8, 2013 06:30 PM
civic91
Apr 21, 2006 07:20 PM
Pikachu
10
Dec 20, 2003 09:41 AM
