Help
Old Nov 19, 2014 | 03:38 PM
Reaper_82's Avatar
Default Help
hi everyone I have a 96 Honda Accord 2.7 liter v6 automatic transmission it runs but upon starting it will idle perfectly fine but once it gets to about 2000 to 3000 in normal weather rpms it starts to cut out but once i go past that it levels out and then just dies I've heard vacuum leak I've heard fuel filter I've heard spark I've checked my spark I am getting spark this all started happening after I power washed the motor so if anybody has any ideas please let me know I miss my Honda
Old Nov 19, 2014 | 04:17 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Help
Check your TPS and MAP sensors, wiring harness and connectors.
Possibly damaged the TPS if it was inundated with water, back probe the sensor with a voltmeter, turn the ignition to II(ON) and watch the voltage change when opening the throttle. It should be a smooth linear voltage change.
fyjimo_jr
Feb 4, 2015 10:33 AM
sethmoman
Dec 18, 2011 02:23 PM
juttsdm5
Sep 9, 2011 08:24 AM
N1ghtM0nkey
Mar 26, 2006 05:45 PM
CzanSOHC
May 25, 2004 05:31 PM
