help
Old Aug 17, 2013 | 09:56 PM
brad1367's Avatar
Default help
Hi. my name is Brad . I just got my daughter a 96 accord and i'm trying to get to run right. here is the problem. I have to crank it over 3 times then it starts. got a code of p1381 and its a 4 cyl
Old Aug 17, 2013 | 10:07 PM
NZXTInerTia's Avatar
Default Re: help
Wut.
Old Aug 18, 2013 | 05:39 AM
Lost Again's Avatar
Default Re: help
Is a bit of a hard read........
OP- Can you give us the code you are getting? Also confirm the engine size, 4 or 6 cyl.
Old Aug 18, 2013 | 08:33 AM
brad1367's Avatar
Default Re: help
sorry, it 4cyl and the code is p1381
Old Aug 19, 2013 | 04:26 PM
Lost Again's Avatar
Default Re: help
First - I'm sorry for the run around and BS. Please don't take my post the wrong way....really want to help but have to understand the issue before that can happen.....and by no means am I an expert/
Ok, you have a "cyp" code. Do you have a volt meter for testing?
I'm not a fan of throwing parts at a car but if you can find a dist in a bone yard for a 96-97 Accord then that is another option.
Not in this gen but some of the others would throw this with a bad alt......doesn't hurt to have a parts store - or yourself - test the alt under load (lights on, blower to max, ac on, ect).
Old Aug 19, 2013 | 07:05 PM
honda.girl.1991's Avatar
Default Re: help
This code it going to stand for one of the following:
Corroded electrical terminals leading to the distributer
-Defective or weak Ignition coil
-missing or incorrectly installed ignition coil shield
-alternator diodes or regulator failing causing irregular line noise
-damaged sensor wire (usually yellow with a purple jacket where shielding begins.
-Defective ECM or PCM
-Faulty Cylinder Position Sensor.
Old Aug 19, 2013 | 11:08 PM
brad1367's Avatar
Default Re: help
thax for the reply's ill let you guys know what i find. what should the volts be under load?
Old Aug 20, 2013 | 01:08 AM
holmesnmanny's Avatar
Default Re: help
This sensor for your vehicle is down by at the lower timing cover at the crank/oil pump housing. For the '94 '95 accords its in the distributor
Old Aug 20, 2013 | 08:02 AM
Lost Again's Avatar
Default Re: help
CYP vs CKP......
all77otorhead
Mar 5, 2024 02:45 PM
lou1sette
Honda Civic (2006 - 2015)
Aug 6, 2018 06:37 PM
Matt Doan
Jul 22, 2016 08:54 PM
hondaracer4vtec
Jan 26, 2006 06:32 PM
90da
Nov 6, 2003 10:15 AM
