Need Help Code 7 flashing on 01 accord LX
Old Dec 7, 2004 | 10:06 AM
all77otorhead's Avatar
Default Need Help Code 7 flashing on 01 accord LX
I am flashing a code number 7 on my 2001 accord LX after the car shut off after jerking whle it was changing gears. can any tell me the meaning of code #7
Old Dec 7, 2004 | 10:38 AM
JimBlake's Avatar
Default Re: Need Help Code 7 flashing on 01 accord LX (OEgarage)
Code 7 is TPS.
But code 70 covers several problems with auto tranny. Is the D4 lamp flashing too? It should have it's own code...
Old Mar 5, 2024 | 02:45 PM
Junkyard42's Avatar
Default Re: Need Help Code p1705 as well as p1399 check engine light flashing and d4 light
The D4 light does not come on and start flashing until I shift out of park check engine light doesn't come on until I shipped out of park along with the check engine light and the D4 light I have an SRS light I am also getting a money sign 00e code this code I can't clear I have changed every sensor on the transmission I've changed the fluid I've changed the rain sensor you know I had the engine itself running great until I shipped out of park I have changed air intake idle control valve change throttle position sensor I've changed speed control of change plugs of change EGR valve have changed event Purge sensor purge valve I've changed the PC PVC check valve I don't know what else to do can anyone give me any idea of where I go from here
Flybye
Apr 29, 2019 06:11 PM
Matt Doan
Jul 22, 2016 08:54 PM
Allan17
Aug 15, 2009 07:58 PM
90da
Nov 6, 2003 10:15 AM
