Help!!!!
Old Mar 24, 2013 | 07:54 PM
Chrys9008's Avatar
Default Help!!!!
So my car has been running fine other then because of the Cali heat has been running hot . I went to go visit my aunt today and she lives kinda up a hill and my car wasn't taking the hill very well like it normally does and then I arrived around the corner and white smoke started coming out of it. I got scared so I turned off the engine and parked it . So is there any way to tell if its the radiator or the head gasket? Please tell me it's a easy fix I'm supposed to be moving to tx in two weeks ! Oh it's a 92 Honda accord lx
Old Mar 24, 2013 | 09:32 PM
NZXTInerTia's Avatar
Default Re: Help!!!!
Start up the car and see where coolant is spraying out of? Sounds to me like you just blew a radiator cap, they are set to a certain PSI so they blow if the system is overloaded.
Old Mar 24, 2013 | 09:53 PM
NvBiker1's Avatar
Or could be a hose
Old Mar 25, 2013 | 05:30 AM
CakewalkHonda's Avatar
where was the white smoke coming from? The engine bay or the tailpipe? The way you described your car not wanting to take the hill like it used to makes me think your rings are going bad and your losing compression in the engine. You may not notice it when you drive normal but you put a bigger strain on your engine when you go up hill.
Old Mar 25, 2013 | 08:56 AM
Chrys9008's Avatar
The smoke was coming from underneath the hood and is it possible to blow the cap if it was still on when I popped the hood ?
Old Mar 25, 2013 | 10:05 AM
NvBiker1's Avatar
Yes, put water in it put the cap on and run it & find
Where its leaking
vteckyle
Mar 11, 2011 09:07 AM
philkehn
30
Jun 17, 2010 02:39 AM
hatchydude
Apr 29, 2009 09:54 PM
98_civic_dude
May 14, 2006 07:57 PM
speed_racer012
Apr 26, 2003 07:23 PM
