HELP
Old Jul 7, 2006 | 06:54 PM
accordlover's Avatar
Default HELP
I HAVE AN 1999 HONDA ACCORD EX WITHOUT LEATHER, I JUST BOUGHT SOME STOCK LEATHER SEATS ON EBAY AND ALL THE SEATS FIT EXCEPT THE DRIVER'S SEAT, THE HARNESS OR PLUG WON'T FIT IS THERE A WAY I GET A DIFFERENT HARNESS OR DIFFERENT PLUG? PLEASE I NEED HELP THANX I'LL BE HAPPY TO GIVE DONUTS TO ANYBODY THAT HELPS ME
Old Jul 8, 2006 | 01:47 AM
BlUAc's Avatar
Default Re: HELP (accordlover)
do wires come out the seat and you plug it in to another plug or does it just plug into tha seat if it does try cutting off the stock seat plug and splice it on the leather seat
Old Jul 8, 2006 | 03:14 AM
Ruskimafia's Avatar
the Ex cloth seats dont come with power option If im Correct?? The ex leather seat are power seats
You can splice the wire or go to a junk and find the connectors i have a junk yard near me that has a leather accord there If u want i can get you the connectors but you will have to wait im out off the country till aug
Old Jul 8, 2006 | 08:25 AM
Default Re: HELP (BlUAc)
THERE ARE 4 STOCK WIRES AND ON THE SEATS THERE ARE 6 WIRES SO WHICH ONE SHOULD I USE?
Old Jul 8, 2006 | 09:40 AM
Ruskimafia's Avatar
match the colors
Old Jul 8, 2006 | 12:29 PM
Default Re: (Ruskimafia)
IS IT KOOL IF I CONNECT TWO WIRES TO ONE?
Old Jul 9, 2006 | 01:26 AM
Ruskimafia's Avatar
depands what color and wat those wire control. Do u have power seats when u bought the car ?
Old Jul 9, 2006 | 02:40 PM
WHEN I BOUGHT THE CAR IT HAD ONLY THE POWER SEATS GOING UP AND DOWN, I MOVED IT BACK AND FRONT MANUALLY AND I RECLINED IT MANUALLY
Old Jul 9, 2006 | 02:49 PM
TheMuffinMan's Avatar
He knows where you live!
In that case, I would pull out a multimeter and see what the voltages going to each of the lines are, if they're the same, go for it and hook them up. Obviously if it's a negative (ground - which I'm sure one of them will be) then you'll be perfectly fine to piggy back it on another grounded cable. Voltages are probably 12v so you should be fine in splicing that one too.
Old Jul 9, 2006 | 02:56 PM
cheeks27's Avatar
my 98 accord will not stay on it will cut on then cut right back off an it will do it when iam driving also an some time it will cut off an cut right back on as if i had started it up my self help help help
Old Jul 9, 2006 | 03:11 PM
cheeks27's Avatar
Default my car will not stay on
my car will not stay on it wiil cut on then back off i have a 98 accord please help me some body
Modified by cheeks27 at 5:57 PM 7/9/2006
Scotteise
Honda Civic (2006 - 2015)
Jul 6, 2019 01:39 PM
JPat
Honda Civic (2001 - 2005)
Feb 19, 2018 09:28 PM
garyc17
Jun 4, 2009 06:20 AM
accordlover
Jul 12, 2006 01:00 PM
accordlover
Oct 23, 2005 04:14 PM
