Headers
Old Mar 10, 2016 | 08:38 PM
Czar2jz's Avatar
Default Headers
What's up guys, Last week I decided to look behind my heat shield and it didn't look pretty lol just rusty and old obviously right. I was wondering what headers would be good for a automatic 1991 cb7?
Thanks.
Old Mar 11, 2016 | 08:34 AM
GhostAccord's Avatar
Default Re: Headers
A4 or A6 OEM will work, be it the Tubular 4-2-1 Exhaust manifold from an F22A4 or the cast 4-2-1 manifold from an F22A6.
Other than that, any of the generic F22A crap from overseas that is found all over ebay will work on a small budget!
Old Mar 11, 2016 | 02:01 PM
Kickstart1's Avatar
Default Re: Headers
eBay is just full,of cheap headers for the CB7 be careful and do some research on any thing you buy !!! Better to run the A4 or A6 if you have a close by junkyard with CB7s
Old Mar 12, 2016 | 12:13 AM
1996accordlx's Avatar
Default Re: Headers
An aftermarket header won't make any noticeable power on a stock motor. That being said, if you can find a decent DC Sports header, grab it. I found one for $50 and recoated it, and it looks great.
Old Mar 12, 2016 | 09:25 AM
Czar2jz's Avatar
Default Re: Headers
Thanks you guys, appreciate the help.
I'll look into OEM and DC.
Old Mar 12, 2016 | 09:30 AM
Czar2jz's Avatar
Default Re: Headers
So I'll ask you this brotha, long headers or short headers?
Old Mar 12, 2016 | 09:47 AM
Default Re: Headers
I am going to assume that you mean long or short primaries......??? What do you have done to your engine to make use of long tube headers?
Short primary 4-2-1 Tri-Y headers are about the best you are going to get for a basic bolt-on build or stock engine!
Old Mar 12, 2016 | 10:26 AM
Czar2jz's Avatar
Default Re: Headers
Not sure what I mean, but what my assumption is with long headers is I feel more power at high rpm vs short headers feeling the power at lower rpms, or would that determine on if Im doing some track time?
My engine is bone stock bro, what I'm going for is a strong stock engine. That I can possibly see some track time and able to run fine as a DD.
Old Mar 12, 2016 | 10:27 AM
Czar2jz's Avatar
Default Re: Headers
But it looks like my best go to would be short headers right? Lol
Old Mar 12, 2016 | 10:51 AM
Default Re: Headers
In order to see power in the higher RPM you would need to increase compression and upgrade your camshaft.
In stock form these engines stop making power at anything above 5500RPM. A set of long tube headers would not benefit you as much as a good quality Tri-Y setup and 2.5" exhaust. That would be what some would call Shorty headers.
Now if you want to start making this thing breath better and increase compression, you can start hitting the 6-7k RPM range and start making some use of a header with longer primaries.
Old Mar 12, 2016 | 12:34 PM
holmesnmanny's Avatar
Default Re: Headers
DC Sports headers are absolute junk. They have crap welding and they are notorious for cracking. I would suggest under no circumstances to buy anything DC Sports.
Old Mar 13, 2016 | 12:13 PM
Czar2jz's Avatar
Default Re: Headers
So how would I get mid range power, guessing between. 1-6k?
I'm going to look into the tri-y setup.
Old Mar 15, 2016 | 11:34 AM
Default Re: Headers
Any feed back on Megan headers?
I have 1991 automatic cb7.
never actually owned a set of Megan..... what part number are you looking at? do they have any material specs available?
Thing you want to look for is the primary tube/pipe wall thickness. The thicker the better. I have a Toucan Industries (Ractive) header from back in the late 90's that used 14 gauge.... You won't find many of them around any more.
A lot of the cheaper overseas ebay garbage use a really thin low grade stainless. This will not benefit you over a stock Honda F22A4 4-2-1 tube manifold. Not only are they loud, they allow way too much heat to be lost from the exhaust too soon. Usually end up rotting from the inside out as condensation forms sits in the seams.
paintballa408
May 21, 2011 06:28 PM
Techy
11
Dec 4, 2006 09:13 AM
gitrdone
Honda Civic (2001 - 2005)
Jun 15, 2006 01:12 PM
-16V-
14
Mar 15, 2004 04:00 PM
civicmatt
Dec 31, 2002 01:35 PM
