HEAD LIGHT CONVERSION
Old May 19, 2005 | 11:33 AM
jonblizz's Avatar
Default HEAD LIGHT CONVERSION
WHAT IS THE BEST HALO PROJECTOR KIT FOR AN 01 ACCORD SEDAN, OR SHOULD I JUST STAY STOCK?
Old May 19, 2005 | 12:09 PM
swoosher21's Avatar
stay stock
jmouchett's Avatar
Default Re: HEAD LIGHT CONVERSION (jonblizz)
Stay stock, the Halo's dont provide enough light
Old May 19, 2005 | 01:27 PM
TxTuner
Guest
Posts: n/a
Default Re: HEAD LIGHT CONVERSION (jmouchett)
stock with a DIY black housing job. Mark off and paint the yellow strip to match the body color
Old May 19, 2005 | 06:41 PM
SuShiBoiiii's Avatar
Default Re: HEAD LIGHT CONVERSION (TxTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">stock with a DIY black housing job. Mark off and paint the yellow strip to match the body color </TD></TR></TABLE> thats the way to go or if ur lazy and rich get them off ebay...
Old May 19, 2005 | 11:33 PM
Mr_EmO's Avatar
Default Re: HEAD LIGHT CONVERSION (SuShiBoiiii)
stOCK
Old May 20, 2005 | 04:13 AM
jonblizz's Avatar
whats the best way to strip off the orange color from the stock housing and make the housing black?
Modified by jonblizz at 7:25 AM 5/20/2005
Old May 24, 2005 | 02:57 AM
PHREAK's Avatar
Default Re: (jonblizz)
i'm curious on this one, too, i have an extra pair of headlights downstairs, just need to figure this one out.
Old May 24, 2005 | 03:17 AM
stinker504's Avatar
If you have the money do a HID retrofit. It'll cost 300-700 bucks, but I think it's worth it.
Old May 24, 2005 | 06:05 AM
Confuc1ous's Avatar
I used to have HID's in the jdm headlights w/black housing i have on the accord, and let me tell you, it looks excellent if you get the right color temperature, and also for the increase in brightness over stock.
Old May 24, 2005 | 09:57 AM
accordselux's Avatar
Me Gusta History
Default Re: (Confuc1ous)
You could do a projector retrofit (real OEM HID projectors) in your housing (or have it done at a shop) with some good 4300-5300k HIDs and have some great light output and good looks.
Old May 24, 2005 | 10:45 AM
sj993's Avatar
Default Re: (accordselux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux &raquo;</TD></TR><TR><TD CLASS="quote">You could do a projector retrofit (real OEM HID projectors) in your housing (or have it done at a shop) with some good 4300-5300k HIDs and have some great light output and good looks.</TD></TR></TABLE>
That or just stick with the stock lenses.
Old May 24, 2005 | 10:52 AM
Me Gusta History
Default Re: (sj993)
Stocks work fine for me but i'd do a complete retrofit if I wanted to do it right from the beginning. Some housings are actually fine for HIDs but most of them are meant for halogen and you get all types of glare
Old May 24, 2005 | 11:20 AM
H2290's Avatar
If you just want to remove the orange and paint the inside black stick them in the oven about 10 minutes at 250 degrees. Then pry them apart with two very skinny screwdrivers just enough to slide a playing card in. Then when you have playing cards all the way around it will seperate. DON'T force it, it will crack.
Old May 25, 2005 | 06:05 PM
PHREAK's Avatar
Default Re: (H2290)
but how do you strip the orange bar for the city lights at the bottom?
Old May 25, 2005 | 06:28 PM
H2290's Avatar
Default Re: (PHREAK)
It is a seperate piece. Once you take the headlight apart it will fall right out.
kelviiv
Paint and Body
Jan 17, 2008 11:07 AM
civicda
Paint and Body
Jun 22, 2007 09:42 PM
preludedude94
Oct 12, 2005 12:19 PM
GreenBean
26
Mar 13, 2005 10:38 AM
quick gixxer
10
Apr 10, 2004 10:49 AM
