have the codes please help
Old Mar 11, 2004 | 07:38 PM
alb_accord's Avatar
Default have the codes please help
this is a 90 accord ex automatic trans.
just finished a swaping the engine (new engine came from a 92 accord dx manual)
CODE 6>>coolant temperature. is this because the white container on the side of the radiator if full and i mean full.
CODE 14. idle air control. >>> i have no idea about this but when i went to get the car from the mechanic he was working on a valve on the top right side of the engine and the rpm were going up and down up and down. where do i start to fix the problem
CODE 41>>> oxygen sensor heater. the heater in the car works fine. is the O2 sensor located under the car on top of the muffler?????? if not where is located???
how much will it cost me to buy a a temperature sensor(code 6) and a idle air control valve(code 14) and a O2 sensor(code 41)????????? is it hard for the instalation?????????
Old Mar 11, 2004 | 07:45 PM
fw190bvi's Avatar
Default Re: have the codes please help (alb_accord)
dont know where the O2 is on ur car.....but everything else should be pretty inexpensive....at least the temp sensor and the o2......idle control might be a little more......ya never know, cause honda charged me 120 for a new drivers side master switch ( mirrors, windows and wiondow lock)
Old Mar 12, 2004 | 03:39 AM
Filthy Focker!'s Avatar
Default Re: have the codes please help (fw190bvi)
It does not mean that you got codes indicating sensor problems that you need to replace the sensors at all.
THe codes are set because your ecu detected some problems. Not really because the sensors are bad..
When getting TC's on a swap, it is sometimes difficult to diagnos since something may not be hooked up right.. It is possible that your coolant sensor is not plugged in correctly or you have damaged the wirese from the sensor to the ecu... Check that first. Then bleed the system... Sometimes, when you coolant temp sensor reading is out of whack, it will throw off your idle and o2 sensor...
Now once you do all this, remove fuse to ECU to reset and start the car. Note any codes...
fs
Old Mar 12, 2004 | 04:54 PM
alb_accord's Avatar
where is th e O2 sensor again?
Old Mar 12, 2004 | 05:07 PM
The_Todd's Avatar
Farts in the shower
Default Re: (alb_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alb_accord &raquo;</TD></TR><TR><TD CLASS="quote">where is th e O2 sensor again?
on a 4th gen its at the base of the header and heat shield. If you need help finding this get your Chiltons or helms
Old Mar 12, 2004 | 08:03 PM
alb_accord's Avatar
mmmm no i don't see it. i got a helms manual but still i don't see it in my car.. i have the heat chield out. the only thing i see it the 4-2-1 exaust manifold and that is it.
Old Mar 13, 2004 | 08:06 PM
gotnos95's Avatar
as far as the code 6 you may want to check the ect sensors. below the distibutor and on the front water neck. they have the same plug and can very easily be switched. you may want to try to switch the plugs around and erase the codes hopefully this should fix the code 6 prob!
93hatchattack
Feb 5, 2008 01:57 PM
EGPHANTOM
Feb 27, 2006 10:22 PM
PWRDbyHseries
Feb 22, 2006 04:53 PM
hatchedzex
May 24, 2004 05:12 PM
BAZ
Apr 28, 2004 08:55 AM
