H23A Vtec
Old Feb 24, 2009 | 06:35 AM
(J)amaicaDM's Avatar
New User
Default H23A Vtec
I just swapped a H23a Vtec into my 1998 Honda Accord. Everything works well except i can't rev over 4000 rpm and my vtec wont come in. Can someone help me
p.s i'm using my stock ECU. I thought it would work cos both engines are OBDII
Old Feb 24, 2009 | 07:31 AM
GhostAccord's Avatar
Default Re: H23A Vtec
Was your stock engine VTEC or NonVTEC?
If it was Non VTEC you will need to buy an OBD2 VTEC ECU.
Old Feb 24, 2009 | 08:29 AM
New User
Yes it was a F23A1 SOHC Vtec with an OBDII computer in it
Old Feb 24, 2009 | 10:10 AM
CEL light on or any Diagnostic Trouble codes?
Probably have to repin/wire the VTEC wires to the ECU. It could be the reverse in the JDM H23 VTEC. Did everything hook right up or did you have to splice/add any wires or connectors?
Old Feb 24, 2009 | 01:19 PM
New User
Everything got hooked back up. the only thing i had to do was match up my four wires on the distributor that came with the H23. Mine had 4 wires for the distributor but the one that came wit the H23 had 8.
The only trouble code that came up was about the vtec circuit
Old Feb 24, 2009 | 01:44 PM
silveraccord2000's Avatar
do u have the rite amount of oil? wat i had to do was take the vtec solenoid off n clean out the screen gasket.
Old Mar 2, 2009 | 07:31 AM
jsamotors's Avatar
Banned
Hi (J)amaicaDM, is your accord Automatic? Did you do a auto to manuel swap?
Old Jun 5, 2009 | 06:57 AM
kg2442's Avatar
New User
I have a 1998 Honda Accord Lx 5 spd and i am wandering if i should get the H23A, or
F20B?
This would be my first engine swap and i don't know what the difference is, and i just need to know which one would be easier and if they will work with the same transmission that came with the car stock?
Old Nov 22, 2009 | 07:42 PM
mozartking's Avatar
I hav the same thing I can't rev over 4,000 rpm I hav a ex with the h23a and I don't know wat to do . What did you do ?
Old Nov 23, 2009 | 09:25 AM
BoostedH23Accord's Avatar
Have you checked the TPS and MAP sensors to make sure they are not backward? I did that once and the car wouldn't run or rev past 2K before shutting off. Switched them around and everything worked perfectly. Good luck!
Old Nov 23, 2009 | 09:43 PM
fastlane2's Avatar
F20B?
Get the H22a, better swap, faster for crying out loud the F20B was made for the 2 liter euro market. Get a kit with the mount, ECU and Tranny From like JDM source or HMO or another repitable dealer. Buying a tranny and engine kit better. Which reminds me I have a F22 auto for sale.
Old May 26, 2011 | 03:04 AM
pomps1234's Avatar
Hey what's up man I just did the same swap I have everything in already I only have to figure out the dizzy wireing I f you still have this info please forward it . Thanks
swizz977
10
May 25, 2011 08:15 PM
sony224422
Aug 3, 2009 05:45 PM
(J)amaicaDM
Feb 27, 2009 07:02 PM
Gunns
13
Jun 1, 2004 11:15 PM
ensracer
Apr 1, 2004 01:28 PM
