h22 problems
Old Oct 23, 2004 | 01:38 PM
h22a92accordex's Avatar
Default h22 problems
ive had my swap in my accord since june and ever since then its over heated while i am sittting in traffic anybody know anything i can check? ive change the thermostat several times.....
and also i feel lik ei dont have the power that i use to have and suggestions??
Old Oct 23, 2004 | 07:32 PM
Nick H's Avatar
New User
Default Re: h22 problems (h22a92accordex)
i hope you realize that an overheating car will do bad things to the motor...it can do anything from warping the head, to ******* up piston rings from the heat...you are sure that you have enough coolant in the motor at all times? if not, you have a leak...if so, make sure your water pump is working...fans won't cause your car to overheat drastically, but if they aren't working they will cause a slight increase in temperature...
Old Oct 23, 2004 | 11:09 PM
H22edAccord's Avatar
Default Re: h22 problems (Nick H)
just a question, is your fans coming on when it warms up
Old Oct 24, 2004 | 07:03 PM
scrubachu's Avatar
Default Re: h22 problems (H22edAccord)
did you bleed the radiator??
Old Oct 26, 2004 | 01:45 PM
i do relize it can mess up my motor ive tried everything that i can think of from chngeing the water pump to draining the radiatior nd filling it back up and bleeding it .. could it be that i dont have a h22a fans and a radiator should i try changeing those???
Old Oct 26, 2004 | 04:34 PM
B SERIES US's Avatar
What computer are you running?
Old Oct 26, 2004 | 04:51 PM
m0t0rhead's Avatar
You probably have low coolant flow through the radiator (If that's the case, you will need to replace it. Modine makes a great all aluminum replacement), a fan either not running at all or operating below spec, or a malfunctioning water pump. A leak will not cause your car to overheat unless you run low on fluid.
These are all possibilities for a car that overheats when at a stop.
Old Oct 26, 2004 | 04:54 PM
m0t0rhead's Avatar
Default Re: h22 problems (Escobar)
As far as your power not being there, if you're driving the car while it's overheating, you may have done some irreversible damage. I would recommend fixing the problem first, then worrying about the power.
Do a compression test so you know what condition you're in. Make sure the you have no codes flagged, check your fuel pressure, and consider a cap/rotor/plug swap using all factory honda parts (since it's cheap).
Good luck.
Old Oct 26, 2004 | 06:22 PM
scrubachu's Avatar
i have an h22 in my 4th gen and i had the same issues. somewhat. i replaced the tstat to a lower temp one, 174 i think, and replaced the termo sensor A. there are a few posts by katyhonda about that sensor. that fixed my problem.
Old Oct 28, 2004 | 03:55 AM
Default Re: h22 problems (B SERIES US)
im running the h22 computer
the thermostat i have is 170 and when i say over heating i mean it gets like 3/4 of the way hot i took it up to honda an dthey said it wasnt a major problem to be conserned about...
and which thermo sensor because i replaced one already
Old Oct 28, 2004 | 06:24 AM
scrubachu's Avatar
the one on the backside of the tstat behind the egr
Old Oct 28, 2004 | 08:26 AM
Brownjd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22edAccord &raquo;</TD></TR><TR><TD CLASS="quote">just a question, is your fans coming on when it warms up</TD></TR></TABLE>
Old Oct 28, 2004 | 09:27 AM
Default Re: h22 problems (Brownjd)
they do but not as soon as they should
Old Oct 31, 2004 | 01:31 PM
ok i gotta the thermo sensor on order and a radiator and fans they will be here tuesday
now when i hit the gas ill have the power up untill 4 grand then it will stop until vtech kicks in....anybody know anything about that
Old Oct 31, 2004 | 03:02 PM
scrubachu's Avatar
since vtec is engaging, ill assume that the wires are added correctly. you add the knock sensor wire? any CEL's?
Old Nov 1, 2004 | 07:29 AM
Default Re: h22 problems (scrubachu)
im not sure what those wire are...... but the pause in power i guess i could call just started like two days ago
Old Nov 1, 2004 | 11:14 AM
Monkey Fing a Coconut's Avatar
fans coming on late are a sign of thermo problems, are u using an oem thermostat or a cheapo autozone one or the like, there was a test and the autozone ones would either open late or not at all, the switch for the fans is after the thermostat which means if its closed, fans dont know the temp of the coolant coming out of the engine which means they dont know its getting too hot, i had the same problem, if the fans dont turn on right at about 1/3 up from cold, then its something with the thermostat
Old Nov 1, 2004 | 05:55 PM
Default Re: h22 problems (twistedbydezign)
its a thermostat from advanced auto parts, what are some thing to do besides change the thrmostat??
Old Nov 7, 2004 | 12:08 PM
that sensor was the problem thank you for your help
raider1qaz
Feb 21, 2013 07:06 AM
rags00prelude22
Mar 12, 2012 09:32 AM
92civicx
Sep 18, 2007 07:08 AM
skylude23
Mar 3, 2007 02:54 AM
mR. Vash
Aug 20, 2004 04:46 PM
