Flashing Code
Old Oct 28, 2013 | 03:04 PM
SlvrJdm's Avatar
Default Flashing Code
Hi there so i changed out the vehicle speed sensor but yet my speedometer is not working and now every time i drive around there a light flashing. Can someone help me out what the code say? i paperclip it and this is what i get. Honda Accord 1994 Coupe 2 Door
Old Oct 28, 2013 | 04:48 PM
GhostAccord's Avatar
Default Re: Flashing Code
4 Blinks on the D4 with the lock-up clutch not engaging could be one of the following;
- Disconnected vehicle speed sensor (vss)
Check to ensure it is connected securely and that all wire pins are fully installed in the connector.
- Short or open in VSS wire.
Check all the VSS wires for a cut or bare wire between the sensor and ECU.
- Faulty VSS.
Where you have replaced the sensor I would check the wires.)
Old Oct 29, 2013 | 06:45 PM
SlvrJdm's Avatar
Could it have to do anything with the tcu if there is one in the car? or any solenoid in the transmission? : ( but yeah i take a look at it this weekend! thank you
mostwanted_ek
Apr 25, 2018 03:58 AM
brgrdx
Mar 24, 2014 11:26 AM
xwhitchx
Jan 25, 2009 03:24 PM
nelson69
Oct 30, 2005 05:13 AM
Kin
Jun 26, 2002 02:34 PM
