A few questions...
Old 01-04-2011, 07:39 PM
gandalf's Avatar
Default A few questions...
I figured out where the oil leak was...thanks to the posters and others here. I figured out that the leak was at my oil cooler..Just have a few questions...1. do you have to remove the coolant lines to replace the gasket?...I've asked everyone and read every book...what size is the O'Ring?No One knows... and I've tried a 27mm socket to remove the oil cooler...won't take a bite......does it require a special tool?
Thanks,
G
Old 01-04-2011, 08:05 PM
redbull-1's Avatar
Default Re: A few questions...
Although you didn't state what year, I would say you're referring to a 4th gen accord.
You don't have to remove the hoses to replace the o-ring. I believe you need a 30mm deep socket to remove the nut.
The O-ring is 62.4x3.1. Honda Part No. 91316-PE7-730 Just get it from the dealer. It list for $2.55.
Old 01-05-2011, 03:18 AM
gandalf's Avatar
Sorry, it's a 92 accord ex...
Old 01-05-2011, 03:02 PM
gandalf's Avatar
Redbull, You were right on the money right down to the part number. I couldn't find a 30mm but I measured the bolt with a crescent wrench at 1 1/8" I hope it works...I used 5 quarts today
Thanks Much for the Help,
G
Old 01-05-2011, 03:18 PM
redbull-1's Avatar
Have you replaced it yet? If not, go to Sears or somewhere to find the 30mm socket. Don't risk rounding the nut with a wrench or something. Using the right tool can save you $ and headaches.
Old 01-06-2011, 08:34 AM
nus_dogg's Avatar
Those O-Ring oil cooler are notorious. Mine was leaking too when I first got done with the H swap. It's cake but thats cause I had a hoist to use at work.
Old 01-06-2011, 01:05 PM
gandalf's Avatar
it does turn the same way as the oil filter to come off...right? I've tried brute force, cheater bars and even tapping the wrench with a hammer...still wont give...I even gave a good cussin...Ideas?
Old 01-06-2011, 01:10 PM
redbull-1's Avatar
Yes, it does turn the same way off. Get a 30mm socket and use a ratchet.
Old 01-06-2011, 01:15 PM
redbull-1's Avatar
Also, when using a ratchet to loosen, use a pull motion instead of a push. Most people think pushing give more leverage; but, I was taught and believe it is the other way around.
Old 01-06-2011, 02:36 PM
gandalf's Avatar
The ratchet and 30mm socket is what I'm using...seems like with all the oil that has been thru there (5 qts yesterday) it should be easier to get off. With the little clearance, physics isn't really on my side, but, I'm gonna work on the force .vs. mass to find an easier way.
This is getting VERY Expensive...I counted 19 qts of oil since this happened. It's time to pull instead of push...
Thanks,
G
p.s
Why was I logged out before finishing this short Message?
Old 01-07-2011, 12:35 PM
gandalf's Avatar
What's the easiest way to get the old O Ring out? I've tried lock picks and a tweaker, next an eyeglass screwdriver
Thanks,
G
Old 01-07-2011, 12:41 PM
redbull-1's Avatar
So, I assume you got the oil cooler off? If so, use a razor blade or something and cut it. Then use a screwdriver or whatever to pry and/or pull it out.
Old 01-07-2011, 01:17 PM
gandalf's Avatar
The old O Ring was so brittle that it came out in pieces. put her back together and NO LEAKS!!!!
Thanks SOOO much for all of your help!!!
G
Old 01-07-2011, 01:24 PM
redbull-1's Avatar
Glad it worked out. One question, did pulling on the ratchet make a difference?
collinsbrianw
12-03-2017 07:23 PM
kushberrymane
01-19-2015 08:53 PM
fastrider213
02-12-2009 04:28 PM
Battle2.0Eg
08-30-2007 03:28 AM
D16Z6racing
01-28-2007 03:24 PM
Quick Reply: A few questions...
