Fan Sensor or Temperature timer?
Old Feb 19, 2008 | 04:49 AM
GoQkRaCeR's Avatar
Default Fan Sensor or Temperature timer?
its -4 degrees outside here in MN and my 98 Accord Fan runs wild!!! the fan seems like its ALWAYS running while im driving the car and when the car is off.
well last nite the fan ran all night and drained my battery.
Do you guys think its the Fan Sensor? also where would i find that in a 98 V6 accord?
or the temperature timer?
Thanks in advance!
Old Feb 20, 2008 | 05:51 AM
GoQkRaCeR's Avatar
Default Re: Fan Sensor or Temperature timer? (GoQkRaCeR)
replacing the sensor this weekend. do i need to drain the coolant first?
Old Feb 22, 2008 | 07:01 AM
CD_Ridge's Avatar
On older models, you can change the temperature sensor without draining the coolant. There should be an air bleed vent where the upper hose enters the engine block. Bleed the air and replenish coolant that was lost.
CD
Homerbsharp
Aug 28, 2011 04:43 AM
dreadyduck
Apr 29, 2008 10:18 AM
hondaccordguy
Dec 10, 2006 07:23 PM
jdub20tx
May 21, 2006 03:04 PM
tianporn
15
Feb 20, 2005 10:56 AM
