f22 header on h22?
Re: f22 header on h22? (allshowaccord91)
First off you should have done a search because this is asked over and over again but no big deal. To answer your question they are a different bolt patter, the F22 looks like this, o o o o The H22 like this: o oo o when comparing the two and unfortunatly it won't work at all.
Re: f22 header on h22? (SpeedFreak77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedFreak77 »</TD></TR><TR><TD CLASS="quote">First off you should have done a search because this is asked over and over again but no big deal. To answer your question they are a different bolt patter, the F22 looks like this, o o o o The H22 like this: o oo o when comparing the two and unfortunatly it won't work at all.</TD></TR></TABLE>
Other way around
Other way around
Re: (TOAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOAB »</TD></TR><TR><TD CLASS="quote">actually hes right. the f22a's are evenly spaced, the f22b's had the inner ports all scrunched.</TD></TR></TABLE>
h22 = o o o o f22b= o oo o
Modified by gaydm.accord at 12:16 AM 1/8/2005
Re: (gaydm.accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord »</TD></TR><TR><TD CLASS="quote">
h22 = o o o o f22= o oo o
correct
incorrect
correct
incorrect
Re: (AVcTcEoCrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVcTcEoCrd »</TD></TR><TR><TD CLASS="quote">
correct
incorrect </TD></TR></TABLE>
actually your wrong, if you had read TOABs post you would know that f22a - o o o o and f22b o oo o and h22 - o o o o dont flame unless you have your facts striaght, if you want further proof of teh f22 differences ill go down to where my 94 is stored and take the heat shield off take a pic, and take the heatshield off my 90 and take a pic and show you the difference. actually your only half wrong, the h22 pattern on the second post is wrong but the f22 is right if they are speaking iof the f22a
correct
i edited mine. i can speak on behalf of the h22a and the f22b cuz i've tried them both and those do not work. as for the f22a i cannot yet speak for.
Re: (gaydm.accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACC0RD22 »</TD></TR><TR><TD CLASS="quote">
actually your wrong, if you had read TOABs post you would know that f22a - o o o o and f22b o oo o and h22 - o o o o dont flame unless you have your facts striaght, if you want further proof of teh f22 differences ill go down to where my 94 is stored and take the heat shield off take a pic, and take the heatshield off my 90 and take a pic and show you the difference. actually your only half wrong, the h22 pattern on the second post is wrong but the f22 is right if they are speaking iof the f22a</TD></TR></TABLE>
first off, i have both motors, f22b and h22a, 1 sitting around and 1 in my car. even if the f22a is o o o o, it wont fit on a h22 head anyways.
Re: (ACC0RD22)
Can the lower portion of the F22B1 (VTEC) Header be used on the Top portion of the JDM H22 Header?
I would think so since they are both 4-2-1?
TIA
TIA
Re: (JDM_CB7)
Let me rephrase that: Can the lower portion of the F22B1 (VTEC) Header be used WITH the Top portion of the JDM H22 Header?
Thanks
Thanks
it might... i think the diameter on the h half would be a bit bigger... so maybe they wont line up quite right.
and for the spacing crap earlier, F22A's have evenly spaced ports... the F22Bx's have the scrunched center ones. if all f22'a were o oo o 4th gen people wouldnt be able to use 1g eclipse turbo manifolds.
Re: (ACC0RD22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACC0RD22 »</TD></TR><TR><TD CLASS="quote">why is that, the spacing is the same, the only thing i can think of that would make it not fit is an incorrect bolt pattern. </TD></TR></TABLE>
the flanges are different.
