F18B series engines - Valve Adjustment
Old 07-29-2010, 09:03 AM
GunSamir's Avatar
Default F18B series engines - Valve Adjustment
Hi,
This is a question about valve clearance adjustment for the F18B series engines. What are the values to be used?
In the FAQ section there are 3 topis about the H22 / F22 engines and values are given as:
Intake: 024 ~ 028 mm
Exaust: 028 ~ 032 mm
Are these values the same for the 1.8 l engines?
Most documentation on the net is about the 2l or 2.2 l engines. There is not much about the 1.8
Thank you
Old 07-29-2010, 11:17 AM
Dannyvho's Avatar
Default Re: F18B series engines - Valve Adjustment
Yes that is correct: for the F18B/F20B/F23Z the Honda shop manual says
intake: 0,26 mm +- 0,02 mm
exhaust: 0,30 mm +- 0,02 mm
which are the exact figures you have.
Valve adjustment is easy: just a screwdriver and wrench and a lot of time...
CivicExMaster
02-26-2008 12:20 PM
JFG Kevin
09-05-2004 02:57 PM
-16V-
02-09-2003 09:35 PM
TDRacing
09-25-2002 01:27 PM
Quick Reply: F18B series engines - Valve Adjustment
