Engine Vibration
Old Jul 3, 2011 | 05:30 PM
meuby's Avatar
Default Engine Vibration
I hope I'm not violating the protocol...part of this issue started when changing my timing belt. But since I can't get the vibration resolved, I thought I should start another post as it's a different issue. Previous post is here:
https://honda-tech.com/forums/honda-accord-1990-2002-2/timing-belt-2906199/
I still have a fairly significant vibration when starting, shutting off, and when in reverse going up a hill (my driveway is on a hill).
Today I loosened all three motor mount bolts in the picture (labeled A, B, and C). I put it in reverse and all was smooth. Tightened A. All was smooth. Tightened B. All was smooth. But when I go to tighten C - I can feel the vibration as I'm tightening it.
I know that my vibration is related to this mount and it's the only one we took off during the timing belt change. Just at a loss as to how to get this thing tightened down without the vibration. Suggestions?
Thanks so much!
Michael
Old Jul 4, 2011 | 07:27 AM
meuby's Avatar
Default Re: Engine Vibration
It's a 2002 Honda Accord SE, 4 cyl.
Old Jul 8, 2011 | 07:06 AM
meuby's Avatar
Any ideas about this?
Old Jul 8, 2011 | 05:35 PM
nus_dogg's Avatar
Well, when I did my timing belt. I had the balancer shaft slightly off it's mark which caused hella vibration to my str wheel when doing 60mph-70mph. Had that going for like 2-4 years of driving this thing.
Then just couple weeks ago when I re-did my timing marks, I had everything put back together as I know my balancer shaft is slightly off, and as I got back on the road, man, the vibration got worse. So right then, I knew that its the balancer shaft that is out of time that causes this majorly shakedown. Anyways, I went back to get it timed and everything and finally, got done and drove her on the road, and man, my car ran smooth as a brand new car. Haven't feel this since I got it back in '05 from my dad. Lol. All this time, I keep thinking that it's a bad axle or something.
Good Luck!
ecchi
Dec 11, 2014 05:10 AM
Spookygeek
May 3, 2008 09:59 PM
dirtracer
Dec 30, 2004 07:16 AM
Jonathan_ED3
Apr 15, 2003 09:12 PM
