Rear Engine Mount .
Rear Engine Mount .
Hello Honda people
What are the symptoms of a rear engine mount going bad ??
Because I had noticed that when I take off hard from a stop or let off the gas at 1st gear or 2nd gear I feel somthing is not wright , it feels like a big bang .
Even I did the test of opening the hood and with the handbrake pulled, put it in 1st and a friend of mine watched the movement of the engine when i tryed to let off the clutch and in 1st gear the engine didn`t make a huge movement but when I put it in reverse the engine did move quite alot !!! is it the rear engine mount going bad because that`s what my friend told me ...
Should I replace the mount or should I get some Energy Suspention engine mount inserts ??!!
Or should I replace the rear engine mount + install the engine mount inserts as well ??!!
Please help guys
Thanks
Marlon.
Please help guys
Thanks
Marlon.
Re: Rear Engine Mount . (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">prothane
a lot stiffer than ES
prothane insert can fix that broken engine mount</TD></TR></TABLE>
2nd on the prothane being stiffer. I can fold the ES ones almost in half... the Prothane I could barely nudge. Engine movement was drastically reduced under simple reving.
Oh so fun to install too....
Re: Rear Engine Mount . (splitime)
yeup, the rear mount is sorta bad
i had the same thing and i just used ES inserts and no more banging on the car
Re: Rear Engine Mount . (HypeR1004)
Sounds like the mount.
There are a total of 4 17mm bolts that you have to remove. The mount is attached to the bottom subframe which is held on by 3 14mm bolts.
The best way to manuever around those is to have a gear wrench of some sort and/or swivel sockets.
Replacing the mount would solve your problem. The inserts will intensify more motor vibration into the cabin.
Good luck.
Good luck.
Re: Rear Engine Mount . (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs »</TD></TR><TR><TD CLASS="quote">Sounds like the mount.
Good luck. </TD></TR></TABLE>
furthermore, A stock Type R mount would be an improvment ovr the stock softy,without all that shake
dakota1820
Honda Civic (2001 - 2005)
07-05-2013 09:02 PM
Greg456
04-08-2004 09:49 PM
