Engine or Tranny ?
Old 05-05-2010, 02:43 PM
alvarado626's Avatar
Default Engine or Tranny ?
Hi Everyone
ok Here's My Problem
About 6 Months a go i Bought a 91 Accord EX Coupe With a 95 V TEC Engine
Everything Works Fine Except 4 The Tranny i Guess.
When Im On a Red Light with the pedal all the way to the floor if i let go on the pedal 4 about an inch my Engine started to shake till i give it more gas
When I start First Gear The Whole Car Rattle Vibrate Bumper, engine, tranny, dashboard
I Already Change Tranny Have New Clutch ,New Flywheel ,New Clutch Master Cylinder, New Sleeve Cylinder,New Axel s New crankshaft pulley, They Said It Was Out Of Balance I Stalled a New one also 2 New motor Mounts i Took the Car to The Shop But They Keep Saying its the Clutch I'm Pretty Sure Its Not Any Suggestions Will Be Appreciated Thank u
Old 05-05-2010, 08:55 PM
phootbag's Avatar
Default Re: Engine or Tranny ?
The engine balancer shaft could be out of phase.
Old 05-06-2010, 01:50 PM
Thx But How Can I Check On That ??
Old 05-06-2010, 03:08 PM
phootbag's Avatar
You would have to remove the timing covers and a small plug on the back of the engine block. It's time consuming but wouldn't cost money in parts to check.
Old 05-06-2010, 03:09 PM
phootbag's Avatar
I'm not sure if this your problem or not but it might not be a bad idea to check since you've pretty much replaced everything else in the car.
Old 05-06-2010, 08:12 PM
Thx I was Talking two a friend of mine and told me that i need to change the flywheel and crankshaft pulley From a 95 V TEC Since Those two that r from The Original Engine 91 what do u think ?? Thx Again
Old 05-06-2010, 08:28 PM
phootbag's Avatar
Seems like if there was a problem with incompatibility with parts the problem wouldn't go away and would only get worse as you increased rpms.
Old 05-06-2010, 08:48 PM
u right !! I'll do what u suggested Thx
Old 05-06-2010, 08:54 PM
phootbag's Avatar
The two mounts you replaced, was one of them the rear engine mount?
Old 05-06-2010, 11:15 PM
no Now That i Remeber I only Replace one The Driver Side By The Belts
Old 05-11-2010, 12:11 PM
i will keep u Inform
Old 05-17-2010, 10:44 PM
Hi I Just Replaced all 4 Motor Mounts and Car still the same Honestly I don't Know What to do Next ................
Old 05-17-2010, 11:57 PM
GlassJAw's Avatar
definitely sounds like the balance shafts are out of sequence, best you get your search on for getting them aligned. If you don't know what they are or aren't very confident with your ability to adjust / check them, I would advise taking it to a mechanic for them to check it for you. Also could you tell us what the engine code / model is??
hell.... since Im such a nice guy I will even post something TouringAccord wrote up for the changing of a cam belt and balance shaft belts on a F22B1 (guessing thats the engine in your car??)
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
Take your car to another mechanic, as anyone with the slightest bit of Honda knowledge would know to check the balance shafts.... as stated below the clutch wouldn't have the symptoms youre describing.
Old 05-17-2010, 11:59 PM
YeuEmMaiMai's Avatar
like everyone suggested balance shafts, if it was ur clutch the car would buck like mad while it was slipping and grabbing
Old 05-18-2010, 08:27 AM
Thank u Guys For Your Advice. I will talk to another mechanic and try to take care of this matter. I really appreciate you all of you guys.
alvarado626
Transmission & Drivetrain
09-09-2010 10:20 AM
alvarado626
04-26-2010 02:12 PM
hondaracin24
03-31-2007 12:09 AM
brodyl05
03-25-2007 06:18 AM
solsearching
10-03-2001 10:24 AM
Quick Reply: Engine or Tranny ?
