Engine swap question
Can a TSX's engine be swapped in 5th gen Accord along with the 6 speed manual? I know that everything can be swapped into anything.... like that RWD H22a Del Sol I've seen here, I'm not talking about anything crazy like that... just a regular swap. Maybe modify here and there. Is it doable? Also, what about type S CL engine? I've seen it swapped into a 6th gen accords. And since H22a could be swapped into 4th,5th and 6th gen, then its a possibility that type S cl motor might bolt right into the bay of the 5th gen.
Re: Engine swap question (ZexyAccord)
The CL-S engine can be made to fit into an V6 Accord chasis.
The K-series engines will be able to fit into 4 cyl accords soon, as soon as HAS finishes the kit.
juicedh22
11-11-2005 09:19 AM
