Engine swap HELP...
Old 07-14-2011, 08:14 PM
csanchez's Avatar
Default Engine swap HELP...
I have an 1993 Honda Accord se with an automatic transmission. I will like, if possible, to do an engine swap and also switch it to a manual transmission. I will like to know if a prelude type-s H22A 97-01 2.2L DOHC VTEC engine will work on my car? In addition, what all I need (parts) if it is possible to do this?
Old 07-14-2011, 08:25 PM
nus_dogg's Avatar
Default Re: Engine swap HELP...
It'll work. Engine will drop in just fine by using a 93-96 Prelude VTEC timing belt side mount and trimming the through bolt hole to make it fit. You'll need to go to the Accord FAQ section and read on it to get a better understanding of whats needed and what not. It's not too hard if you know what you're doing.
Good Luck!
Old 07-14-2011, 08:34 PM
csanchez's Avatar
Thanks.
I just joined so I'm currently limited to what I can do. I don't have access to the FAQ section.
Old 07-15-2011, 02:34 AM
Jmb106jr's Avatar
Welcome to HT. You have access to the FAQ, it is a sticky at the top of the thread page. here is the link https://honda-tech.com/forums/honda-accord-1990-2002-2/1990-2002-accord-faq-1664547/. Good luck to you and your build.
Old 07-15-2011, 08:04 AM
csanchez's Avatar
THANK YOU. I appreciate it..
WesleyLD
01-26-2015 06:25 PM
410ruga
03-01-2014 10:39 AM
ClicKinG30-06
Transmission & Drivetrain
04-11-2010 03:33 PM
heaththemanshehan
11-07-2008 04:40 PM
nsruffryder34
08-01-2003 03:18 PM
Quick Reply: Engine swap HELP...
