Engine Shakes
Old Nov 3, 2010 | 04:59 PM
alvarado626's Avatar
Default Engine Shakes
Hola Guys Hope Someone Can Help me Out
Every time I Turn on My Headlights
Engine Shakes
I Checked Voltage Using Multimeter its Reading 14.30
91 Accord 2 Door
Battery About 6 Months Old
Alternator About 8 Months
Any Help Will Be Appreciated Thx
Old Nov 3, 2010 | 05:57 PM
BetAda0064's Avatar
Default Re: Engine Shakes
that sounds pretty random. make sure your engine mounts arent blown and the ac is off. it might be causeing the shakes. If it still shakes after that. post back
Old Nov 3, 2010 | 08:31 PM
A/C Doesn't Work All Three Motor Mounts r New
Old Nov 3, 2010 | 09:03 PM
saucejon1983's Avatar
Start with the basics, as you already have, you say the motor mounts are new, so let's just say that's not the problem. When was the last time your vehicle had a tune up? partially fouled plugs can work properly under normal conditions, but the extra load your alternator places on the engine could cause spurattic misfires. This could result in the engine shaking. Then you can start diving more into that line of though, check the resistance of the plug wire, I believe about 10k ohms per foot should be an ok general spec. And check the points on the cap. Then verify that your engine stays within idle speed specifications when a load is placed on the engine. Let's see where that gets you and go from there.
Old Nov 4, 2010 | 12:35 AM
Thx Sauce I'll Work On That
Old Nov 4, 2010 | 03:44 PM
shawn_crx's Avatar
When your engine shakes does your RPM drop?
Old Nov 5, 2010 | 09:01 AM
Yes It Does Almost to 500rpm
Old Nov 5, 2010 | 12:43 PM
shawn_crx's Avatar
Either your headlight are using alot of juice, battery is going bad, or your Alternator is not charging the system well. Seem like it's putting a good load on the battery which cause the RPM drop or bad connections somewhere.
Old Nov 6, 2010 | 02:08 PM
I Relocated My Battery to the Trunk Bout 2 Months a go
Old Nov 6, 2010 | 02:37 PM
holmesnmanny's Avatar
Clean your iacv.
lil kid
Honda Civic (2001 - 2005)
Jul 22, 2008 02:11 AM
meno19
14
Aug 2, 2006 03:03 AM
Kryptonite
Feb 20, 2006 11:22 AM
turbotime
16
Mar 10, 2004 05:12 AM
Roadrnnr
Sep 5, 2001 05:19 PM
