engine noises
Old Dec 31, 2005 | 10:29 PM
Defcon2030's Avatar
Default engine noises
i had my 94 Accord Lx belts replaced about 5 weeks ago because the mileage was 144k+. the new belts worked fine, but now for the past 2 weeks or so, they squeak pretty bad. it always does it when i first start the car up, but if it's wet out, it oes it non stop when the engine RPMs aren't above around 3k. is there some spray for this or do i need some kind of greese?
Old Dec 31, 2005 | 10:47 PM
BLKFLSH's Avatar
Default Re: engine noises (Defcon2030)
They have probably stretched. Check and readjust. I had 100k miles on my original belts and like you I figured that was long enough. Damb NAPA belts made noise (only right after cold startup, then would be quiet), even adjusted to the correct tension. Should have gotten Honda belts for it. I never even had to adjust the Honda belts. Good luck
Old Dec 31, 2005 | 11:56 PM
P_Adams's Avatar
They require readjusting. After the initial run-in, ALL belts require retightening *except serpentine belts (which use tensioners).
P
Old Jan 1, 2006 | 01:09 AM
Honda-Master's Avatar
Default Re: engine noises (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">They require readjusting. After the initial run-in, ALL belts require retightening *except serpentine belts (which use tensioners).
P</TD></TR></TABLE>
Old Jan 1, 2006 | 09:23 AM
00accordguy's Avatar
Default Re: engine noises (Honda-Master)
how do you adjust them?
Old Jan 1, 2006 | 09:33 AM
BLKFLSH's Avatar
Default Re: engine noises (00accordguy)
First of all, how many belts do you have?
swooooshin
Jun 1, 2018 08:25 AM
thecrackerjack
13
Feb 18, 2008 01:14 PM
BUDtoker
Nov 9, 2007 09:19 AM
JL 74
Feb 13, 2007 07:30 PM
kihun_cha
Oct 17, 2004 10:57 PM
