Engine going...what to do...
Old Feb 19, 2003 | 08:05 PM
.dave's Avatar
i HAS questions ?
Default Engine going...what to do...
The engine and transmission in my 91 Accord Ex are about to die. This is the second engine, the last one had timing belt issues which killed the valves last July. I was changing the oil the other day and theres coolant leaking down the block everywhere, and oil coming out around the top of the pan. The transmission shifts very hard, similar to dropping it into gear from neutral. Other times when I'm driving along usually around 30-35 mph it will up to almost 5000 rpm but the car doesn't increase speed. I'm thinking about swapping in an H22 or F20 and I would like to change to a manual transmission. I'd most likely try and find a wrecked Prelude in a junkyard and grab whatever parts I could off of it. The guy at the local shop is a dick and said that he won't do a tranny swap so I figure I'm on my own. How difficult is it?
Old Feb 20, 2003 | 03:40 AM
KGAccord's Avatar
Default Re: Engine going...what to do... (dtmamg)
how much money are you looking to spend? a h22 plus auto-manual will cost more than what the car is worth.
Old Feb 20, 2003 | 09:06 AM
.dave's Avatar
i HAS questions ?
Default Re: Engine going...what to do... (KGAccord)
Yeah I'm also considering just getting a new car; don't know what to get though. I'd probably spend around $12,000(on a car, not a swap).
BerniniCaCO3
Feb 22, 2011 12:21 PM
itzonlydav
Jul 11, 2008 02:34 AM
morales232002
Nov 18, 2006 03:31 PM
Swift1
Jun 2, 2005 11:04 AM
Jerry31
Jun 29, 2004 09:54 PM
