Engine cutoff
Old Jul 29, 2006 | 07:42 AM
radioman17@hotmail.com's Avatar
Default Engine cutoff
92 Accord LX starts, warms, runs, then just shuts down sometimes in motion sometimes in idle with no warning signs or sounds, however, seems to idle rougher as compared to past. 121K miles regularly maintained. Any ideas and advice welcome. Thanks.
Old Jul 29, 2006 | 08:34 AM
Intense3.2's Avatar
Default Re: Engine cutoff (radioman17@hotmail.com)
When it shuts off, what are you doing...? Driving?
Old Jul 29, 2006 | 08:39 AM
Default Re: Engine cutoff (Intense2.2)
Driving and just parked idling before driving.
Old Jul 29, 2006 | 08:47 AM
Intense3.2's Avatar
Do you have the ac on...? Any aftermarket parts...? Please try to be as descriptive as possible.
Old Jul 29, 2006 | 09:02 AM
Sometimes I have A/C and CD/radio on but not every time. In addition, after car stops I wait about 2 minutes and restart. On one occasion car cutoff three times in one short drive. This was recently and temps were in high 80's to low 90's - could this have effect.
Old Jul 29, 2006 | 09:09 AM
Intense3.2's Avatar
This sounds really weird, wait for some of the other guys to respond, & use the search feature... im not sure what it could be. Just make sure that everything under the hood is sound. ex: all electrical connections are secured & just look over the motor to see if anything is out of place.
Old Jul 29, 2006 | 06:56 PM
ucd_4_life's Avatar
what happens to the cluster when it shuts off?
Modified by ucd_4_life at 8:07 PM 7/29/2006
Old Jul 30, 2006 | 03:31 AM
Duane_in_Japan's Avatar
Default Re: Engine cutoff (ucd_4_life)
When it dies and has a hard time restarting you need to check for fuel pressure (flow) out of the test port on top of the fuel filter and you need to check for spark with a spare spark plug stuck into a plug wire that you pulled from the head and grounded a spare spark plug to ground, let us know if you do not have spark or fuel or any other info you can share please. Of course this will be better with two people.
Old Jul 30, 2006 | 08:52 AM
Default Re: Engine cutoff (Duane_in_Japan)
The car is an automatic. What's a cluster?
Old Jul 30, 2006 | 09:19 AM
philadd's Avatar
Possible causes that I can think of off the top of my head include:
1. main relay
2. ignitor
3. ignition coil
Old Aug 7, 2006 | 06:35 AM
Problem solved. Turns out it was the igniter. Since igniter is inside distributor new cap and rotor were needed and replaced. Total cost for igniter, cap and rotor $97.00. Thanks to all for your help.
hellakornhaus
Apr 5, 2007 12:53 PM
dynamo
Mar 28, 2007 05:27 PM
Acco12dv6
Sep 28, 2006 08:18 AM
evans
May 20, 2006 04:59 AM
HondaRcB
Apr 16, 2002 06:46 PM
