engine ??
Old Dec 25, 2008 | 01:46 AM
wesk18's Avatar
Default engine ??
i put my hand n cover the hole where the oil cap goes on my 95 accord n oil appers in my hand, iam guessing its spitting the oil is this normal ??
second i found some oil in one of the spark plug at the bottom of the plug engine side not where the wire goes is this normal??
thanks people!
Old Dec 25, 2008 | 01:53 AM
YeuEmMaiMai's Avatar
Default Re: engine ??
milage on the car was the car running when you did that?
time for a new tube seal set......fairly easy to do
Old Dec 25, 2008 | 02:08 AM
wesk18's Avatar
where does the tube seal set goes?? how to install it ?
yea the car was running iam just wondering if thats normal
Old Dec 25, 2008 | 02:22 AM
yeah it's normal if the car was running. to replace the tube seals you need to remove the valve cover.
Old Dec 25, 2008 | 05:25 AM
P_Adams's Avatar
Yes, It's Normal.
There are actually two sets of Spark Plug Tube seals.
1) The ones on top, directly under the valve cover. and
2) The lower ones, located under the Camshaft/rocker shaft assembly.
Whenever I do this job, I go straight to the lower ones. They contribute 90% of the time to this condition so I do BOTH the lower's AND uppers at the same time.
P
Old Dec 25, 2008 | 05:40 AM
GhostAccord's Avatar
Default Tube seals
Yellow = Valve cover to rocker assembly, spark plug tube seals
Red = Rocker assembly to head, spark plug o-ring seals
Old Dec 25, 2008 | 09:23 PM
wesk18's Avatar
Originally Posted by P_Adams
Yes, It's Normal.
P
aight thanks man
Old Dec 25, 2008 | 09:28 PM
wesk18's Avatar
Default Re: Tube seals
thanks dude
wesk18's Avatar
thanks dude
SeanaK
Engine Management and Tuning
10
Jun 22, 2011 09:18 AM
erik_mullen
Mar 13, 2011 07:07 PM
EG6_978
Sep 13, 2008 02:37 PM
el_toro_de_magnifico
Apr 15, 2008 11:13 PM
buzzboy8
Dec 27, 2004 03:48 PM
