Electrical Problem with Speedo
Old Oct 27, 2005 | 05:08 AM
BuyImports2's Avatar
Default Electrical Problem with Speedo
A guy I work with has a 94 accord and has been having some electrical issues. Sometimes while he drives, his gauges all drop to zero, then bounce back up to normal. He says he hears a clicking from behind the glovebox (i'm pretty sure that is where the ecu is) whenever the problem occurs. I did a search and most electrical problems are fuse related, but if you blow a fuse, wouldn't things just stop working? Thanks
Modified by BuyImports2 at 6:50 AM 10/27/2005
Old Oct 27, 2005 | 05:26 AM
H2290's Avatar
Default Re: Electrical Problem with Speedo (BuyImports2)
What do you mean by everything? Every single gauge? If it's just the speedo and tach then something may be up with the VSS.
Old Oct 27, 2005 | 05:41 AM
Default Re: Electrical Problem with Speedo (H2290)
I think it is just the speedo and tach. What is the VSS? *i just searched and found it is the vehicle speed sensor, althought I know nothing about what it is or how it works...lol
Old Oct 27, 2005 | 10:38 AM
H2290's Avatar
The vehicle speed sensor mounts on the transmission just below the shift linkage. If you pop the hood and stand on the passenger side and look just below where the linkage meets the tranny you will see three
blacc_ej1
Oct 14, 2009 01:49 AM
vedha
Oct 9, 2009 09:46 PM
Delano5050
May 5, 2007 08:52 AM
methos713
22
Apr 14, 2004 05:12 PM
